07-22-2010, 17:59 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | Below 100% pinout tested using ZTE N290 InfinityBox remove user code. Uses the model in Inifnity ZTE-N281. COM9 [VCP0] selected module v3.51 Action: read unlock codes unlock method: read codes Model: ZTE-N281 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: VIVO_ISDB_850B_P107A2V1.0.0B10 Version: 09AZTENJ35_09A 83 byte(s) read imei: 35234604xxxxxx connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 Finished, time used: 2 min 7 sec Remove/Install battery now ! |
The Following 6 Users Say Thank You to cbcelular For This Useful Post: |
07-22-2010, 18:13 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, read firmware from N290 (as N281) and send full flash backup to [email protected] so we will be able to add support for this model. Thank you ! |
07-22-2010, 18:40 | #4 (permalink) | |
Member: 217679 Status: Offline Thanks Meter: 95 | Quote:
11-30-2010, 20:38 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | GS102 cable working fine with this model... For Repair imei use MODE 2 Last edited by daroas; 11-30-2010 at 20:45. |
The Following User Says Thank You to daroas For This Useful Post: |
12-07-2010, 20:08 | #8 (permalink) |
Registered User Join Date: Sep 2009 Location: 01100001 01110001 01110101 011
Member: 1128665 Status: Offline Sonork: 100.1605565 Thanks Meter: 11 | jejeje goood Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: CHILE_ISDB_850B_P107A2V1.0.0B04 Version: 09AZTENJ35_09A 83 byte(s) read imei: 35852203008379 connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to distriaccel For This Useful Post: |
12-23-2010, 20:55 | #9 (permalink) |
Junior Member Join Date: Dec 2008
Member: 935553 Status: Offline Thanks Meter: 2 | ZTE-N290 cable GS102 unlock ok! COM4 [VCP0] selected modulo v3.70 Action: "sp-unlock" Metodo unlock: smart fast Modelo: ZTE-N290 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6235,E04 Dato: 2000.00.00 Version: 1.0 Version: CHILE_ISDB_850B_P107A2V1.0.0B04 Version: 09AZTENJ35_09A 83 byte(s) read imei: coneccion Ok 189 byte(s) read Leyendo datos... reading data #2... construcción de nuevos datos.. escribiendo datos... 177 byte(s) read Leyendo datos... 972 byte(s) read construcción de nuevos datos.. escribiendo datos... verifying... verificacion Ok Listo Finalizado, tiempo usado: 17 sec Quite/coloque la bateria ahora ! |
The Following User Says Thank You to kazootek For This Useful Post: |
02-13-2011, 17:38 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please, send full flash backup (or RapidShare AG, Cham, Switzerland link) to [email protected] Thank you ! |
02-13-2011, 20:06 | #13 (permalink) | |
Only flash image file will be enough. I do not have an experience to make this phone working for 900/1800, it may be that it's even impossible due to phone hardware type. Anyway, you can try to flash phone with another firmware from support area and see results. | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
