12-11-2010, 11:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 41
Member: 63828 Status: Offline Thanks Meter: 15 | ot-216 unlocking unlocke a ot-216, ==== [12/11/2010 3:46:29 PM] ==== COM4 [VCP0] selected module v3.70 Device: Alcatel-216X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6BB1:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.7AF96 47D.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_572F5926].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 7AF9647D rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 26592F57 code offset: 00000000 ffs offset/size [01]: 00700000/000F8000 TCL-ID identification version: 462 provider: 216X-2IRGMG2 customization: CP46CB01 customization: XP46CB01 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00700000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP46CB01 customization name adjusted flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 98009600000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98009600000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-216X_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_ 36_SP1_V34__system_log_7AF9647D_572F5926_20101211-154830.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! phone gave an error message when switching on so i flashed it with the flash given in the support site ==== [12/11/2010 3:57:50 PM] ==== COM4 [VCP0] selected module v3.70 Device: Alcatel-216X Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 216X-2ERGMG2-462_XP46CB01_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2009-12-15_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6BB1:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.7AF96 47D.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_572F5926].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 7AF9647D rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 26592F57 code offset: 00000000 ffs offset/size [01]: 00700000/000F8000 TCL-ID identification version: 462 provider: 216X-2IRGMG2 customization: CP46CB01 customization: XP46CB01 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-216X_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_ 36_SP1_V34__system_log_7AF9647D_572F5926_20101211-155844.B0X.bin Area: Firmware flash: 98009600000000:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP46CB01 customization name adjusted customization: CP46CB01 customization name adjusted customization detected: CP46CB01 customization: CP46CB01 flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-216X_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_ 36_SP1_V34__system_log_7AF9647D_572F5926_20101211-160051.B0X.bin Finished, time used: 2 min 57 sec Remove/Install battery now ! and now the phone is off, how to revive |
The Following User Says Thank You to rizni For This Useful Post: |
12-13-2010, 06:06 | #3 (permalink) |
Member: 63828 Status: Offline Thanks Meter: 15 | the message i didn't note down, but it was stuck in that message so i flashed it and now its not switching on. the phone reads as 216X-21RGMG2. can i find the original flash file for this. thank u |
12-13-2010, 11:01 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,972 | Hi, 1. check phone battery value 2. try to flash phone once again, I think it should be alive We do not have other flash files for this model, all files that we have already uploaded in support area. btw, do you have original flash backup ? |
12-18-2010, 09:36 | #7 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Madagascar Age: 35
Member: 603285 Status: Offline Thanks Meter: 31 | Repair IMEI But after it will be locked now i've 50 Alcatel OT 216x LOCK BY ORANGE MADAGASCAR and i don't know how to unlock it It's impossible to do this online because phone is permanently blocked i don't know ho to unlock it! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
