Old 08-28-2011, 00:52   #1 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
OT-305 won't unlock
Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34 from Orange Mali
Reading Eeprom
=== [8/27/2011 10:24:43 PM] ====
COM2 [VCP1] selected
module  v4.01
Device: Alcatel-305X, 305A
Checking data, wait...
Action: read ffs/eeprom
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:ADF9:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\[Boxes]\InfinityBox\MModule\backup_security\id.487700E1.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34.BIN_68334BDF].rpl
New firmware found (v.4.01, database date: 19.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 487700E1
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, DF4B3368
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 16B
provider: 305X-2CRGML5
customization: CP16CE10
customization: XP16CE10
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__ffs...
file saved: C:\[Boxes]\InfinityBox\MModule\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__ffs_20110827-222849.B0E.bin
original imei: 35776903692641
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__system_log_487700E1_68334BDF_20110827-222853.B0X.bin
Finished, time used: 4 min 6 sec
Remove/Install battery now !
Reading Firmware
==== [8/27/2011 10:42:51 PM] ====
COM22 [VCP3] selected
module  v4.01
Action: read firmware
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
error: no any expected answer : wrong answer after chip id request
flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
reading: Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__firmware_part_1_of_1...
file saved: C:\[Boxes]\InfinityBox\MModule\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__firmware_part_1_of_1_20110827-225410.B0M.bin
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__system_log_487700E1_68334BDF_20110827-225416.B0X.bin
Finished, time used: 11 min 21 sec
The mentioned files are inside the archive Multiupload.com - upload your files to multiple file hosting sites!
Unlocking
==== [8/27/2011 10:54:28 PM] ====
module  v4.01
Action: rebuild security area
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
startup code area #1 check...
startup code area #1 fixed
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->086376FC
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A__system_log_487700E1_68334BDF_20110827-225659.B0X.bin
Finished, time used: 2 min 28 sec
After unlock, the phone blinks, restored to the initial state by writing the backuped firmware part.
Old 08-28-2011, 01:37   #2 (permalink)
Grand S's Avatar
Member: 954179
Thanks Meter: 83
Why not rebuilt secu before unlock?
Old 08-28-2011, 02:45   #3 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
thanks mate for your reply, it can't help, the phone blinks again
for sure the security area is bad
module  v4.01
Action: repair security area
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
sec info (fast) detection...
relocation table detected
name table[00] #7000000 detected
customization detected: CP16CE10
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A__system_log_487700E1_68334BDF_20110828-022258.B0X.bin
Finished, time used: 6 min 1 sec
module  v4.01
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A__system_log_487700E1_68334BDF_20110828-022913.B0X.bin
Finished, time used: 2 min 24 sec
Old 08-28-2011, 18:06   #4 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 500
bro first write imei on back of the phone and make spunlock.
Old 08-28-2011, 21:04   #5 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
==== [8/28/2011 8:36:07 PM] ====
COM3 [VCP0] selected
module  v4.01
Action: "repair imei"
new imei: 357769036926417
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Backup required data Done
====>  Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
pass #3
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write: imei
Write: imei
Write: imei
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34__system_log_487700E1_68334BDF_20110828-204056.B0X.bin
Finished, time used: 4 min 29 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== [8/28/2011 8:41:56 PM] ====
module  v4.01
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 487700E1
rom info ver: 05
version: 16B
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
file saved: C:\[Boxes]\InfinityBox\MModule\backup_security\Alcatel-305X,305A__system_log_487700E1_68334BDF_20110828-204413.B0X.bin
Finished, time used: 2 min 13 sec
It does not work, bro, according to the phone's owner, someone has already played with it.
Thanks mates for your help. We will not worry for some lost cherries
thanks
Old 08-29-2011, 09:01   #6 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
THEN DOWNLOAD THIS FILE FROM INFINITY SUPPORT AND FLASH ALL WILL BE OKAY. 305X-2DVDKE1-166_XP16CH10_JRD23_08A_PCB01_GPRS_MT6223P_S00%5B1% 5D.MAUI_08A_W08_36_SP1_V34_2010-08-09_.bin
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.40982 seconds with 9 queries
