03-14-2010, 14:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: bulgaria,plovdiv Age: 53
Member: 62866 Status: Offline Thanks Meter: 49 | OT-305x unlock problem COM4 [VCP0] selected module v3.25 Device: Alcatel-305X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AC5E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.45071 A81.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl rom info detection finished ==================== New firmware detected (v.3.25, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 45071A81 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XP16CF13 error: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08667144 ..................security area (sec info, part #1) detecting size... error: security area (sec info, part #1) size is incorrect: 01C0 instead of 0374 file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X__system_log_45071A81_2FA8B35C_20100314-141618.B0X.bin Finished, time used: 3 min 56 sec Remove/Install battery now ! RapidShare: 1-CLICK Web hosting - Easy Filehosting please solve this problem br stefan |
03-14-2010, 17:21 | #3 (permalink) |
Member: 62866 Status: Offline Thanks Meter: 49 | re COM4 [VCP0] selected module v3.25 Device: Alcatel-305X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 357769030816721 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AC5E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.45071 A81.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl rom info detection finished ==================== New firmware detected (v.3.25, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 45071A81 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35776903081672 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... .................. pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 .............................. Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: imei flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected error: relocation table offset is unknown error: jump table is not found or incorrect can't detect customization version error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08667144 ..................security area (sec info, part #1) detecting size... error: security area (sec info, part #1) size is incorrect: 01C0 instead of 0374 Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_45071A81_2FA8B35C_20100314-181458.B0X.bin Finished, time used: 4 min 55 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM4 [VCP0] selected module v3.25 Device: Alcatel-305X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AC5E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.45071 A81.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl rom info detection finished ==================== New firmware detected (v.3.25, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 45071A81 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XP16CF13 error: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08667144 ..................security area (sec info, part #1) detecting size... error: security area (sec info, part #1) size is incorrect: 01C0 instead of 0374 file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X__system_log_45071A81_2FA8B35C_20100314-181903.B0X.bin Finished, time used: 2 min 51 sec Remove/Install battery now ! but phone is steel locked |
03-14-2010, 17:39 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, New software version with this version support will be released on days. |
Alcatel ot-c550 unlock problem | rubeltelecom | FuriousGold | 18 | 01-20-2013 12:03 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
Ot-c630 Unlock Problem | sonitex | FuriousGold | 1 | 09-24-2007 11:01 |
MT-560...OT-531 unlocking problem | Kashif Khan | Mitsubishi | 6 | 02-13-2006 14:52 |
xg1 ot 0320 unlocking problem | Moosani | Wray´s Products | 5 | 12-12-2004 19:27 |
