Old 09-21-2011, 14:47   #1 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 500
Ot-306 restart after unlock
PLEASE INFINITY TEAM HELP WITH THIS PROBLEM AFTER UNLOCKING 306X PHONE JUST KEEPS ON RESTARTING BELOW IS LOG:
module v4.01
Device: Alcatel-306X, 306A
Checking data, wait...
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:840B:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.075E9F53 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_0888B855].rpl
New firmware found (v.4.01, database date: 19.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 075E9F53
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, 55B88808
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 961
provider: 306X-2AVDKE3
customization: CI96CA00
customization: XI96CA00
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (fast) detection...
searching sec info#1...
search sec info#1 finished
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
relocation table detected
name table[00] #7000000 detected
customization name adjusted
customization detected: CI96CA00
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->086403C0
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-306X,306A__system_log_075E9F53_0888B855_20110921-162545.B0X.bin
Finished, time used: 2 min 23 sec
Remove/Install battery now !
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 09-22-2011, 09:11   #2 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
Please anyone upload ot-306 free file on infinity support,because i flashed with a file from support but its still locked, the file is from comcel,thanks.
Old 09-22-2011, 18:00   #3 (permalink)
Member: 1043909
Thanks Meter: 60,912
Hello,
Please, try this: For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock:
1. use "MModule" software v3.22 or newer
2. use "Write" button from software "Service" page and write original imei (from phone back label)
3. make "sp-unlock"
Old 09-23-2011, 12:15   #4 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
Originally Posted by yellowboss View Post
hello,
please, try this: For newest alcatel models (f.e. 203, 708, v541 etc.) that freez/reboot after sp-unlock:
1. Use "mmodule" software v3.22 or newer
2. Use "write" button from software "service" page and write original imei (from phone back label)
3. Make "sp-unlock"
when i use the above method the set begins blinking.
Old 09-23-2011, 12:41   #5 (permalink)
Member: 177238
Thanks Meter: 11
Originally Posted by YellowBoss View Post
Hello,
3. make "sp-unlock"
any another solution for 306x? I think that this problem cause infinity can not decode or recalculate security zones for this phones with new firmware. so waiting for updates from Infinity team
Old 09-23-2011, 13:22   #6 (permalink)
Member: 52214
Thanks Meter: 13
try to write this back-up
Old 09-26-2011, 12:02   #7 (permalink)
Member: 177238
Thanks Meter: 11
Question
I have so backup file, but I can't load ti trough e2p or firmware
Loading file v.02...
error: data error !
Loading failed, probably damaged data file
how to write it back?
Old 09-26-2011, 12:48   #8 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
Originally Posted by ssam alex View Post
i have so backup file, but i can't load ti trough e2p or firmware
loading file v.02...
Error: Data error !
just fullflash phone with files from support.
Old 09-28-2011, 19:26   #9 (permalink)
Member: 177238
Thanks Meter: 11
Arrow
there is no full flashes for 306x in support. only for 306a. My friend gave me full from 306x. After flashing that full - phone became alive, but locked. lately I will send it to support
Old 09-29-2011, 09:00   #10 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
there is no full flashes for 306x in support. Only for 306a. My friend gave me full from 306x. After flashing that full - phone became alive, but locked. Lately i will send it to support
the two files on support can flash 306x but will remain locked,to comcel just upload asimfree file on support, thanks.
Old 10-02-2011, 09:29   #11 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
please infinity team anyone with 306x freesim,help i have many sets to unlock,thanks
Old 01-09-2012, 13:37   #12 (permalink)
Member: 5926
Thanks Meter: 275
Use this file Alcatel-306X,306A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__fullflash_part_1_of_1_20120109-141906.B0M.bin
It is readed from one OT-306x from Wind Italy NOT locked.
Or try to use OT-305 file, I think is almost the same phone
http://www.gsmarena.com/compare.php3...&idPhone2=3187
Old 09-10-2012, 13:59   #13 (permalink)
chotky's Avatar
Member: 39460
Thanks Meter: 17
hello im in same situation , i full flash with the mediafire flash , now the phone is on but the screen is totaly white !!! any other full flash maybe the lcd is not compatible with this version , the phone is from ( la poste ) france
please help with full flash
Old 09-12-2012, 10:11   #14 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 500
Originally Posted by chotky View Post
hello im in same situation , i full flash with the mediafire flash , now the phone is on but the screen is totaly white !!! Any other full flash maybe the lcd is not compatible with this version , the phone is from ( la poste ) france
bro now infinity can unlock this phone via codes, no need unlock by cable.
Old 02-10-2014, 11:00   #15 (permalink)
Member: 1141738
Thanks Meter: 28
can you please upload the full flash again link is dead and i have a similar problem and phone stuck in boot logo
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.23634 seconds with 9 queries
