Old 10-09-2009, 14:08   #1 (permalink)
nifboy's Avatar
Member: 645987
Sonork: 100.1612601
Thanks Meter: 112
ot-600 virgin mobile fullflas hear
ot-600 virgin mobile fullflas hear....
COM5 [VCP1] selected
module v2.90
Device: Alcatel-S621X, S621A
Checking data, wait...
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:FE03:A000
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 7CB8E5BF
rom info protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 05738FBF
ffs offset/size: 00C00000/00400000
ffs address assigned: 00C00000
TCL identification...
version: ØýS
provider: F.xEjmEJ
customization: fSÙÜõÞ
TCL identification done
detect device sec info...
detect device sec info finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 00000000000000
reading: Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V38__fullflash_part_1_of_1...
file saved: D:\INFINITY\alcatel\ot-600\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V38__fullflash_part_1_of_1_20091008-192007.B0X.bin
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V38__system_log_7CB8E5BF_40708CFA_20 091008-192048.B0X.bin
Finished, time used: 3552 sec
Remove/Install battery now !
1. Download Link:Click here to download file
http://rapidshare.com/files/29068887..._1_of_1_2.html
Old 10-10-2009, 10:51   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
This phone is not supported completely yet.
We will try to release new software for this model ASAP.
Also, please, send a mail to [email protected] with information about this thread, so we will be able to send you new software for test.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-05-2009, 01:04   #3 (permalink)
Member: 130995
Hello,
Please, try to flash phone with this software with VM621 flash file from support area.
http://www.infinity-box.com/download...dule_v2.93.rar
Do not forget to make full flash backup for emergency case !
Waiting for your results.
Old 11-05-2009, 11:46   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Originally Posted by InfinitySupport View Post
Hello,
Hello!
I had flashed ot-600 to s621x firmware, It was T-Mobile firmware after flash phone stuck on Alcatel logo, I did flash with other file now it is dead, can you give correct flash file for this model ?
P.S. It is aslo virgin mobile.
Regards, Ali
Old 11-05-2009, 11:55   #5 (permalink)
Member: 643472
Sonork: 100.96901
Hello,
Hi !
I've checked you upload new files for OT-600, can we use them to repair ?
Regards, Ali
Old 11-05-2009, 12:39   #6 (permalink)
Member: 643472
Sonork: 100.96901
Hello !
It is done! I used OT-600 flashes and tick on "unlock during flash" and "smart write"
Flash file which I used.
600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK.B0M.bin
logs :
COM15 [VCP0] selected
module v2.93
Device: Alcatel-600
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001A03:A00B
status: 01
Boot Done
Initialize ...
flash: 98000300000001:40000000000000
Initialize Done
Set baud ...
115200
Set baud Done
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
ffs address can not be detected, value from database assigned: 00C00000/00400000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
original imei: FFFFFFFFFFFFFF
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
firmware patch sp-lock #1 is not required
firmware patch sp-lock #2 is not required
Special operation Done
Write ...
.damaged firmware
.damaged hardware
sec info (fast) detection...
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
Area: Firmware
Write: Firmware
searching sec info#2...
search sec info#2 finished
searching sec info#3...
search sec info#3 finished
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..area 0x01 size is zero
................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
customization: CJ26CW10
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
..................security area (sec info, part #1) detecting size...
done
done
done
Write Done
Finalization ...
Finalization Done
Finished, time used: 1538 sec
Thanks infinity team
Regards, Ali
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 11-05-2009, 13:13   #7 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
Well Done Ali Good Test Report
Regards
UMER
Old 11-16-2009, 22:52   #8 (permalink)
Member: 130995
Hello,
Here is direct unlock solution for Alcatel models.
It's beta solution, need to test it and see what will be the results.
Please, try to unlock phone with this new software:
http://www.infinity-box.com/download...dule_v2.94.rar
It is no need to flash phone, just use "SP-Unlock" button from software "Service" page.
Old 11-25-2009, 08:45   #9 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
lin error plz load again
Old 11-27-2009, 15:13   #10 (permalink)
Member: 130995
Hello,
You can download latest MModule from Infinity-Box support area.
Old 12-04-2009, 01:43   #11 (permalink)
Member: 508840
Thanks Meter: 13
hi please help me i have here virgin mobile(microsnapper) when tick menu appear "please wait" only? please give me solution? thanks.
Old 12-04-2009, 12:20   #12 (permalink)
Member: 130995
Hello,
Did you tried to make "format ffs" in "complete" mode ?
alcatel ot-s320 and ot-600 product password MGT SOFTWARE Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 6 01-10-2010 08:34
i need urgent flash files for OT-600 virgin gsm-faruks.com Infinity-Box 8 11-16-2009 22:53
Ot-600 ::: SOLVED ::: Nadjombe PolarBox 3 1 09-24-2009 17:08
Ot-600 Unlock Successfull Allunlockingsource Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 3 09-06-2009 13:13
virgin mobile ...type NRJ MOBILE PLAYER farid29 Infinity-Box 1 06-23-2008 12:47
Page generated in 0.30382 seconds with 10 queries
