12-14-2009, 21:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Phitsanuloke, Thailand Age: 46
Member: 201888 Status: Offline Thanks Meter: 62 | OT 600 (Virgin VM621i) I have problem about Alcatel OT 600 (Virgin VM621i) I want to change logo on mobile I write this firmware to phone "600A-2DCECO3-266_XJ26NG12_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_Pt.B0M" Here is log. ==== log: [12/15/2009 3:17:34 AM] ==== COM14 [VCP1] selected module v2.99 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware 600A-2DCECO3-266_XJ26NG12_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3303:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A62A519A rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 startup code area #1 check... warning: rpl file not found: D:\Program Files\InfinityBox\MModule\id.A62A519A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305].rpl warning: rpl file not found: D:\Program Files\InfinityBox\MModule\id.A62A519A._JRD25_06B_P CB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_B F8F7305_.rpl warning: rpl file not found: D:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305].rpl warning: rpl file not found: D:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_ 28_SP1_V38.BIN_BF8F7305_.rpl ==================== warning: unknown rom info structure: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305 Unknown firmware detected (v.2.99, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_A62A519A_C4B7397C_20091215-032352.B0X.bin Area: Firmware flash: 98000300000001:08EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->00006F54 error: can not recalculate address range, allowed offset is too small: 00006F54 error: can't calculate security area (sec info, part #1) security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ26NG12 customization: CJ26NG12 flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ26NG12 customization: CJ26NG12 flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_A62A519A_C4B7397C_20091215-032844.B0X.bin Finished, time used: 650 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! When finish, I cannot open my phone I write this firmware to phone "600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK.B0M" And another firmware But same problem Help me please Thanks |
12-19-2009, 05:34 | #8 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 914747 Status: Offline Thanks Meter: 22 | i got orignal backup i readed this file when vm621i was not in list so i readed it by salecting s621x Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V38_1_20090718-050022.B0X vm621i full flash readed from fone |
12-20-2009, 18:28 | #9 (permalink) |
Member: 201888 Status: Offline Thanks Meter: 62 | I think flash files from support for spiansion chip But my OT 600 have toshiba chip inside Please upload new flash files to support Thanks |
12-20-2009, 20:05 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mwmobile2 send this file to [email protected] : D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_A62A519A_C4B7397C_20091215-032352.B0X.bin Also, what other files EXACTLY you have tried to write into phone and what was the results ? |
12-21-2009, 07:32 | #11 (permalink) | |
Member: 201888 Status: Offline Thanks Meter: 62 | Quote:
Thank sir today i send this files to [email protected] I flash with this firmware 1. 600A-2DAVDO3-266_XJ26NU1C_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06- 16_Claro_Dominican_Republic_En_Fr_Es_It_Pt.B0M 2. 600A-2DCECO3-266_XJ26NG12_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06- 16_En_Fr_Es_It_Pt.B0M 3. 600X-2AOTFA1-260_XJ26CK00_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-04- 20_En_Fr_Es_De_Pt.B0M 4. 600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06- 16_En_Fr_Es_It_De_VM621i_Virgin-UK.B0M 5. 600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06- 16_En_Fr_Es_It_De_VM621i_Virgin-UK_simfree.B0M with other model 1. S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22 _En_Fr_Serbian_simfree.B0M 2. S621X-2ATBHR1-544_XD54CS03_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07 -22_En_Srpski_De_Hrvatski_Slovencina_T-Mobile.B0M 3. S621X-2AVRGB1-545_XD54CW08_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008- 08-06_En_Fr_Es_It_De_Virgin.B0M 4. S621X-2AVRGB1-556_XD55CW40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2009- 01-07_En_Fr_Es_It_De.B0M But same problem I wait for help Thanks | |
12-22-2009, 02:29 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...e_v3.00_v2.rar Let's see results. |
12-22-2009, 15:01 | #13 (permalink) |
Member: 201888 Status: Offline Thanks Meter: 62 | Thanks for support sir When I flash with firmware OT600 in support total 5 files My phone is dead same before this log COM7 [VCP6] selected module v3.00 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3303:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_9B8BA950].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A62A519A rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, 50A98B9B code offset: 00000000 ffs offset/size [01]: 01020000/00FE0000 TCL-ID identification version: customization: customization: TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01020000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished warning: security area (sec info, part #1) buffer#1 size is invalid: 00000000 sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 480000BE4A4011 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 startup code area #1 check... warning: rpl file not found: E:\Program Files\InfinityBox\MModule\id.A62A519A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305].rpl warning: rpl file not found: E:\Program Files\InfinityBox\MModule\id.A62A519A._JRD25_06B_P CB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_B F8F7305_.rpl warning: rpl file not found: E:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305].rpl warning: rpl file not found: E:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_ 28_SP1_V38.BIN_BF8F7305_.rpl ==================== warning: unknown rom info structure: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_BF8F7305 Unknown firmware detected (v.3.00, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V34__system_log_A62A519A_9B8BA950_20091222-204717.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->00006F54 error: can not recalculate address range, allowed offset is too small: 00006F54 error: can't calculate security area (sec info, part #1) security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ26CW10 customization: CJ26CW10 flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ26CW10 customization: CJ26CW10 flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V34__system_log_A62A519A_9B8BA950_20091222-205641.B0X.bin Finished, time used: 10 min 53 sec Remove/Install battery now ! Loading file v.04... S621X-2ATBMK1-555_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, 50A98B9B code offset: 00000000 ffs offset/size [01]: 01020000/00FE0000 rom info structure: 2nd [enhanced] generation TCL-ID is present Loaded file w/protection: startup code area #1 |
The Following User Says Thank You to mwmobile2 For This Useful Post: |
12-22-2009, 15:03 | #14 (permalink) |
Member: 201888 Status: Offline Thanks Meter: 62 | When I Flash with this firmware S621X-2ATBMK1-555_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M Can open again !!! But LCD show ALCATEL logo only ---------------------------------------------- COM7 [VCP3] selected module v3.00 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware S621X-2ATBMK1-555_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3303:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_CBC62112].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A62A519A rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, 1221C6CB code offset: 00000000 ffs offset/size [01]: 01020000/00FE0000 TCL-ID identification version: 556 provider: S621X-2AVRGB1 customization: CD55CW40 customization: XD55CW40 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01020000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 480000BE7A6011 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #1)... not required Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V34__system_log_A62A519A_CBC62112_20091222-185340.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected error: relocation table offset is unknown error: jump table is not found or incorrect can't detect customization version customization: XD55CW40 flash: 98000300000001:18E59F00000000 flash: 98000300000001:18E59F00000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:18E59F00000000 flash: 98000300000001:18E59F00000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V34__system_log_A62A519A_CBC62112_20091222-190348.B0X.bin Finished, time used: 11 min 0 sec Remove/Install battery now ! |
12-22-2009, 15:04 | #15 (permalink) |
Member: 201888 Status: Offline Thanks Meter: 62 | After I format with complete mode This log -------------------------- COM7 [VCP3] selected module v3.00 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3303:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.A62A5 19A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_9B8BA950].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A62A519A rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, 50A98B9B code offset: 00000000 ffs offset/size [01]: 01020000/00FE0000 TCL-ID identification version: 555 provider: S621X-2ATBMK1 customization: CD55DB40 customization: XD55DB40 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01020000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 480000BE4A4011 flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V34__system_log_A62A519A_9B8BA950_20091222-193457.B0X.bin Finished, time used: 1 min 23 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! My phone dead again |
alcatel ot-s320 and ot-600 product password | MGT SOFTWARE | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 01-10-2010 08:34 |
ot-600 virgin mobile fullflas hear | nifboy | Infinity-Box | 11 | 12-04-2009 12:20 |
i need urgent flash files for OT-600 virgin | gsm-faruks.com | Infinity-Box | 8 | 11-16-2009 22:53 |
Ot-600 ::: SOLVED ::: | Nadjombe | PolarBox 3 | 1 | 09-24-2009 17:08 |
Ot-600 Unlock Successfull | Allunlockingsource | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 09-06-2009 13:13 |
