01-13-2010, 17:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | OT-660A imei repair doesnt work i have here a an ot-660a that came in for unlock and imei repair.i did the direct unlock and unlock was successful.but when i do imei repair to phone i try to turn the phone on and it gets to alcatel logo and then turns off.please infinity team can you update mmodule and correct this problem with ot-660 i am using mmodule 3.02 P.S. i also tried flashing phone with flash file from support for ot-660a which is the same flash originally in phone.after flash unlock ok.but after imei repair phone shuts off at alcatel logo. thank you BR Gee4234 |
01-13-2010, 18:17 | #2 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | here is log could this be the problem why imei repair doesnt work.i have noticed that all logs posted by users working with this phone imei in log is all 000000000000 seems that mmodule cannot detect the imei in phone COM1 [Serial0] selected module v3.02 Device: Alcatel-660 Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 011872000864420 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F203:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:08EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4D1C8 797.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_9144C4E9].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 4D1C8797 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, E9C44491 code offset: 00020000 ffs offset/size [01]: 01000000/00FE0000 TCL-ID identification version: 334 provider: 660A-2DAVDO3-S40 customization: CJ33NP0A customization: XJ33NP0A TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:08EA0000000000 Backup required data Done ====> Patch required data ... ....................................... original data found, method-A Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ33NP0A customization: CJ33NP0A flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CJ33NP0A customization: CJ33NP0A flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-660_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_4D1C8797_9144C4E9_20100113-140815.B0X.bin Finished, time used: 6 min 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BR Gee4234 |
01-13-2010, 18:24 | #3 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | another thing i have noticed is that people who tried imei repair with model ot-708 and ot-600 were not successfull and those models also in log have imei 000000000000.seems that mmodule cannot detect imei with these models. please infintiy look into this problem BR Gee4234 |
OT 383 OT 203 imei repair not work | bananin | Infinity-Box | 1 | 01-10-2010 13:09 |
12 Aug 2008: Alcatel-OT-C7xx, OT-C8xx, OT-V7xx, OT-S5xx imei repair in test etc. | InfinitySupport | Infinity-Box | 35 | 09-28-2008 20:40 |
x700 imei repair don't work ! | kimo59 | NSPRO | 2 | 04-17-2008 11:54 |
E900 - Imei repair, not working. | mobilextreme | NSPRO | 8 | 09-19-2006 13:23 |
Z105 imei repair dont work? | alejandroveliki | NSPRO | 8 | 05-22-2006 09:28 |
