ot 808 no supported! please, support new boot and chip...example alcatel 0t808 COM6 [VCP0] selected module v3.21 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: 02 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AA error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 7 sec Remove/Install battery now ! |
not supported by infinity box................ |
Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: JRD35_08A_HW Software version: MAUI.08A.W08.40.SP1. Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 356389032224575 Finished, time used: 2 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: JRD35_08A_HW Software version: MAUI.08A.W08.40.SP1. Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 356389032224575 Finished, time used: 2 sec Remove/Install battery now ! COM15 [VCP0] selected module v3.22 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: 02 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AA error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 9 sec Remove/Install battery now ! COM15 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:8003 status: 02 boot packet size: 0400 error: bootcode start error: A4 not authorized: 000000A4 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. unknown hardware: contact to support: [email protected] 2. hardware is damaged: check hardware, water inside etc. Initialize Fail Finished, time used: 19 sec Remove/Install battery now ! |
ot-808 Quote:
