12-01-2009, 13:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | ot e221 unlock failed dead Code: ==== log opened: [12/1/2009 7:53:24 PM] ==== Application: C:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.37 S/N: 64A3:0112 Wait... Device: Aiko-51G Done Device: Alcatel-E221 COM3 ready ==== log: [12/1/2009 7:53:56 PM] ==== COM3 [VCP10] selected module v1.37 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20091201-195505.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .......... .......... error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 68 sec Remove/Install battery now ! |
12-01-2009, 19:24 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Are you sure that phone become damaged ? As I can see software can not find required data and exit w/o any phone changes. Try to repeat operation hut press and HOLD phone "Power" button during all unlock process. |
12-02-2009, 02:59 | #3 (permalink) | |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | Quote:
phone has totally damaged sir when i power on it shows only red lights in the upper back of lift top. is it ok to use file from support in flashing? to make phone power on.. and what file do i have to use please attached here the correct flashfile in order and i will get it to download support area. Code: COM3 [VCP0] selected module v1.37 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20091202-094811.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .......... .......... error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 68 sec Remove/Install battery now ! | |
12-02-2009, 04:35 | #4 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | already done.. i flashed with firmware and lp from support then phone has power now. closed thread logs for unlocking.. Code: COM3 [VCP0] selected module v1.37 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20091202-105233.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 80 sec Remove/Install battery now ! |
The Following User Says Thank You to lorenzo roberto For This Useful Post: |
Alcatel OT-800 Unlock Failed [SOLVED USING 2.39 BETA] | yozh | PolarBox 3 | 8 | 09-06-2010 21:54 |
ot-e221 unlock[ANSWERED & SOLVED] | haroum | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 14 | 04-09-2010 20:18 |
alcatel ot s320 unlock failed | talatmehmood | Easy-Unlocker | 6 | 01-26-2009 09:46 |
failed to unlock ot-E221 alcatel | faisal butt | Easy-Unlocker | 7 | 03-13-2008 23:54 |
OT- E221 unlocking Error | Faheem Anjum | FuriousGold | 3 | 03-01-2008 14:09 |
