11-22-2009, 16:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: lebanon Age: 39
Member: 175671 Status: Offline Thanks Meter: 40 | ot203 unlock problem i do repair secuirty area then phone power on normaly but always locked i flash the phone with many firmware from support and do the progress and the same any help ? |
11-22-2009, 21:29 | #3 (permalink) | |
2. flash phone with any firmware 3. make "unlock" 4. make "Read detailed information" post here operation log for 2., 3., 4. | |
11-23-2009, 00:10 | #5 (permalink) |
Member: 175671 Status: Offline Thanks Meter: 40 | flashing COM4 [VCP0] selected module v2.95 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware 203X-2BRGTE5-37E_XM37CC30_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-09-01_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5D1A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091122-231310.B0X.bin Area: Firmware flash: 01227E221A2201:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CM37CC30 customization: CM37CC30 flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091122-231427.B0X.bin Finished, time used: 111 sec Remove/Install battery now ! ---------------------------------------------------------------------------------------------------------------------- this information after flashing , because when unlock it can't read information because hang on alcatel logo Action: read information Model: Alcatel-203X, 203A, 203E Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6223, E05 Hardware version: JRD23_NEP_08A_HW Software version: MAUI.08A.W08.36.SP1. Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 352474030280300 Finished, time used: 2 sec Power off phone now ! --------------------------------------------------------------------------------------------------------------- unlocking COM4 [VCP0] selected module v2.95 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5D1A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CC30 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091122-231650.B0X.bin Finished, time used: 77 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Last edited by cobra02a; 11-23-2009 at 00:17. |
The Following User Says Thank You to cobra02a For This Useful Post: |
11-23-2009, 00:54 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to unlock phone with this software: http://www.infinity-box.com/download...e_v2.96_v3.rar What is the results ? |
11-23-2009, 01:15 | #7 (permalink) |
Member: 175671 Status: Offline Thanks Meter: 40 | it's the same problem COM4 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5D1A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CC30 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091123-001453.B0X.bin Finished, time used: 79 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-23-2009, 03:01 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash phone with this firmware and make unlock again: 203X-2AAHNL1-377_XM37CF31_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-06-26_En_Nl_Fr_De_Tr.B0M.bin |
11-23-2009, 14:48 | #9 (permalink) |
Member: 175671 Status: Offline Thanks Meter: 40 | COM3 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware 203X-2AAHNL1-377_XM37CF31_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-06-26_En_Nl_Fr_De_Tr.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5D1A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091123-133937.B0X.bin Area: Firmware flash: 01227E221A2201:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CM37CF31 customization: CM37CF31 flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091123-134358.B0X.bin Finished, time used: 297 sec Remove/Install battery now ! -------------------------------------------------------------------------- ==== log: [11/23/2009 1:44:12 PM] ==== COM3 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5D1A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 377 provider: 203X-2AAHNL1 customization: CM37CF31 customization: XM37CF31 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CF31 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091123-134535.B0X.bin Finished, time used: 78 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! -------------------------------------------------------------------------- the same problem |
11-23-2009, 19:58 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thanks for your patience ! Please, make one more test: 1. flash phone with 203EX-2BRGGB1-37E_XM37CS32_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_3 6_SP1_V28_F1_2009-09-01_En_Fr_Es_It_De.B0M.bin 2. try to make unlock What is the results ? |
11-23-2009, 23:46 | #15 (permalink) | |
Member: 175671 Status: Offline Thanks Meter: 40 | Quote:
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
Alcatel ot303,ot203 unlock not possible! [ANSWERED] | ADE4x4 | PolarBox 3 | 13 | 03-12-2010 12:06 |
OT203 Unlock UNsuccessful by MicroBox calculator | goranapo | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 11-08-2009 06:30 |
w200 unlock problem i think exe problem please lead look here | saily | Cruiser Suite | 22 | 08-15-2007 14:31 |
