to our dear infinity coder hello coder, pls add reset in SVC mode for spd6820/8810 chips. i know this is not that hard for you to do, so pls consider this request. thanks. selected from soft sc6815 emmc generic Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... Normal Mode init Sync... Init Ok , reset settings ... Format Error! Done Elapsed: 00:00:30 Reconnect Power/Cable! |
If SVC mode ReadInfo Supported, then format option will be working too Try your self & post result here. |
hello pasc, thank you for your suggestion I will check your log text and your request carefullly. |
