11-28-2016, 13:20 | #1 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2329547 Status: Offline Thanks Meter: 15 | to our dear infinity coder pls add reset in SVC mode for spd6820/8810 chips. i know this is not that hard for you to do, so pls consider this request. thanks. selected from soft sc6815 emmc generic Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... Normal Mode init Sync... Init Ok , reset settings ... Format Error! Done Elapsed: 00:00:30 Reconnect Power/Cable! |
11-28-2016, 14:05 | #2 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
If SVC mode ReadInfo Supported, then format option will be working too Try your self & post result here. | |
11-28-2016, 16:10 | #3 (permalink) |
Member: 2329547 Status: Offline Thanks Meter: 15 | well, i guess this phone has nand cpu. i just selected emmc 6815 to see what would happen. i think if coder is interested this chips can be supported. still waiting coder's reply on this. wbr, |
The Following User Says Thank You to pasc For This Useful Post: |
11-28-2016, 23:48 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello pasc, thank you for your suggestion I will check your log text and your request carefullly. |
