05-12-2016, 09:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | P1000 chinese no chance for read firmware Code: operation : Check / Read Info [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , [HYNIX] H8BCS0UN0MCR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : 504D81C9880C9AA3313885C9BFD49C56 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : eidolon15_nand_gb2 ProdModel : eidolon15_nand_gb2 Device : eidolon15_nand_gb2 AndroidVer: 4.1.1 MTKxCPU : MT6575 MTKxPRJ : ALPS.GB2.MP.V2.47 SECURITY : IMEI_SW [1] : 9EA1B0E27159DBF IMEI_SW [2] : 9EA1B0E27159DBF BTMAC Addr : FFFFFFFFFFFF WiFi MAC : FFFFFFFFFFFF Done! Elapsed: 00:00:33 Reconnect Power/Cable! Finish at : [11/05/2016 / 17:38:16] Code: Operation : Read Flash [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , [HYNIX] H8BCS0UN0MCR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : 504D81C9880C9AA3313885C9BFD49C56 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Too old device, FW reading not supported! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! |
05-12-2016, 09:33 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Unfortunately - have just one device with 6575 nand. It not enough to make something working for FW read / write. Will keep looking for a samples, but not have any eta. |
