Old 06-19-2016, 16:53   #1 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 174
P780 FW error
Hello need help there is LENOVO P780 that dont want flash.Have try with diference flash files but no results.Have done also erase flash but the same pb
Operation : Flash [ v1.47 ]
======= Flash
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019064314734A306860405412083
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048606A383204105
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : B1672374B2BE318D53D9F16F167AAC7F
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Disabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3862 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_*****_row.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:53
Reconnect Power/Cable!
Also have try by latest version CM2 1.50
Old 06-19-2016, 17:13   #2 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,447
======= Flash
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:53
Hello,
EMMC Damaged -
Old 06-20-2016, 15:17   #3 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 174
Originally Posted by pradeep_kus View Post
Hello,
EMMC Damaged -
Hello but phone before fw worked.
Old 06-20-2016, 20:17   #4 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 574
Hello,
Some times emmc is in dying state so mobile work buggy... just check flash ic test maybe emmc is in read only state
Sent from my S_plus using Tapatalk
Page generated in 0.26503 seconds with 7 queries
