04-25-2011, 12:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: India
Member: 1505057 Status: Offline Thanks Meter: 38 | Pagaria 9045 blinking log is here- detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:2BEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... .................................................. ...... ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: LCSH23_08A_PCB01_GPRS_MT6223P_S00.LKDLK03_8_28_1_1 T06M0817_M501.BI detecting firmware build... .................................................. .............. done detecting product-id... .................................................. .............. done detecting languages... .................................................. .............. error: can't detect language parameter #1 warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. Finished, time used: 1 min 31 sec Remove/Install battery now ! |
04-25-2011, 20:08 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make erase whole flash chip, next write to phone follwing firmware: flashfiles/1MTK/_MT6223/LCSH23_08A_PCB01_GPRS_MT6223P_S00.LKDLK03_8_28_1_1 T06M0817_M501__Pagaria-P9045_2009-08-17_16m_En_Hi.B0M.bin |
04-27-2011, 14:23 | #3 (permalink) |
Member: 1505057 Status: Offline Thanks Meter: 38 | after flash same problem handset not on. Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00C80000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-00FFFFFF firmware area: 00000000-0037FFFF detecting ffs/eeprom structure pass 1... .............. ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: LCSH23_08A_PCB01_GPRS_MT6223P_S00.LKDLK03_8_28_1_1 T06M0817_M501.BI detecting firmware build... ..................................... firmware date/time: 2009-08-17 15-58 hw1: LCSH23_08A_HW hw2: MAUI_LCSH23_08A done detecting product-id... .................................................. .............. done detecting languages... ................................. language parameters detected detected languages: En Hi Finished, time used: 1 min 17 sec Remove/Install battery now ! |
Where can i download program for blinking sms | Ari | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 01-29-2009 17:47 |
please help "in c25 v10 light automatically blinks and switches off " | sidharthaharish | x1x to x45/x50 | 2 | 12-29-2001 22:40 |
a1018s blink only | eureka8888 | Old Ericsson Phones & Sony Phones | 2 | 10-04-2001 09:39 |
Help need 3330 Ver.305 double blink CS repairer | ced1298 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-29-2001 18:13 |
A 36 Blink and off | pez8210 | x1x to x45/x50 | 0 | 08-05-2001 22:23 |
