12-10-2009, 10:33 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Heare is sigmatel 7600 new firmware detected HEARE IS FULL OK SET READED LOG:- Code: COM6 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F803:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.02, database date: 10.12.2009): HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_ALX_S33_18_ML_A_1_V03.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_ALX_S33_18_ML_A_1_V03.BIN ver. sw 2: 6302_C37C_ALX_S33_18_ML_A_1_v03, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_ALX_S33_18_ML_A_1_V03__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_ALX_S33_18_ML_A_1_V03__fullflash_20091210-145351.B0M7600 Finished, time used: 529 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to debmobile For This Useful Post: |
12-26-2009, 12:29 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Bharat > Jalandhar
Member: 566335 Status: Offline Thanks Meter: 160 | i Flashed Sigmatel 7600 with above given file set flashed successfully ...... But set is now dead.. before flash set was on restart condition... i flashed & formatted.... but still same... what should i do now. This file was in the set before Flash HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_AL X_S33_18_ML_A_1_V03.BIN |
12-26-2009, 12:56 | #6 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: india
Member: 1012744 Status: Offline Thanks Meter: 67 | Quote:
12-26-2009, 13:31 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try another close to yours: flashfiles/ChineseMiracle/_MT6225/HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_AL X_18_S35_MOYAN_ML_A_1_V02_16m_En_Ru_Fr_Es_Id_Vn_Tr _Farsi_Pt_Ar.B0M.bin |
Heare is sigmatel t2 new firmware detected | debmobile | Infinity-Box | 13 | 05-16-2011 19:18 |
Sigmatel 5130 new firmware detected | debmobile | Infinity-Box | 2 | 01-21-2010 20:44 |
Heare is simoco sm-324 new firmware detected | debmobile | Infinity-Box | 5 | 12-20-2009 16:47 |
Here is sigmatel s3 new firmware | bhavesh123 | Infinity-Box | 2 | 12-10-2008 18:36 |
6300 New firmware detected...what is this? | KUBAT1 | Infinity-Box | 7 | 01-12-2008 22:58 |
