pana g51e stops on panasonic @supporter as i am trying to falsh ,unlock nothing happens no communication i am using g50 rj45 cable need to solve this waiting |
Please, see answer for your problem here: http://forum.gsmhosting.com/vbb/show...63&postcount=2 |
@infinity it is so helpfull the given link bro thanks but i have the box pack cable came with infinity box [g50] i have checked cable pinout from the given link and secondly the flash file i have tried to falsh like given instruction 1=firmware +language +map but after press power on and hold button no responce need some help i have gone through the link u gave thanks |
hello! if you using right cable (G50) then only few possible errors: 1. wrong com port selected. 2. RJ45 cable inserted in wrong connector 3. phone side connector have too many rubber and doesent allow to fit in phone properly 4. faulty phone hardware. here is some hints: when you push unlock and right com port is selected- one of box LED should start blinking. by this you can understand that com port selection is right. insert cable to left RJ45 box port cut rubber to make connector fit in phone fully |
@infinity i have only one rj45 in box it is [slim] there is no rubber near phone secondly when i press unlock green light blink ,as we have to hole power button i do so but no responce waiting |
@chiragp double check your cable and be sure that phone connector not damaged and cable inserted completely inside phone connector. |
Hello! please run cable selector and check G50 cable pictures number 2, 3 this is how you need to modify your cable to fit in phone properly |
@supporter here r some info of my cable and pinout http://img152.imageshack.us/img152/5...picturewm8.jpg http://img208.imageshack.us/img208/8...70a100xfc0.jpg also i have checked the internal h/f socket of phone it is fresh and complete in connectivity |
