03-31-2009, 09:48 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 214987 Status: Offline Thanks Meter: 3 | Pana01 module Bug log: [3/21/2009 5:18:16 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 26 sec Remove/Install battery now ! ==== log: [3/21/2009 5:18:56 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 25 sec Remove/Install battery now ! ==== log opened: [3/21/2009 5:20:09 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.64 S/N: 61A6:0112 Wait... Device: ZTE-A61 Ready ==== log: [3/21/2009 5:20:28 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: TEL-P108A11V1.0.0B03 CELTEL-P108A11B01-EnFr-01 g3dBV2.0 04.12.00 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-static_20090321-172047.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-security_20090321-172048.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20090321-172054.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_lock-area_20090321-172113.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 66 sec Remove/Install battery now ! ==== log opened: [3/21/2009 6:00:02 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.64 S/N: 61A6:0112 Wait... Device: ZTE-A61 Ready Loading file v.02... ZTE-A61_main_lp_CELTEL-P108A11B01-EnFr-BF01.B1M.bin loaded ==== log: [3/21/2009 6:00:25 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: TEL-P108A11V1.0.0B03 CELTEL-P108A11B01-EnFr-01 g3dBV2.0 04.12.00 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-static_20090321-180042.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-security_20090321-180043.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20090321-180050.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 247 sec Remove/Install battery now ! ==== log: [3/21/2009 6:05:23 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 6 sec Remove/Install battery now ! Device: ZTE-A66 WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/21/2009 6:07:01 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 6 sec Remove/Install battery now ! Device: ZTE-A61 ==== log: [3/21/2009 6:08:30 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -BF-P108A11V1.0.0B03 17 00 15 Aug 21 2007 17 00 15 CELTEL-P108A1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-static_20090321-180847.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-security_20090321-180847.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20090321-180854.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_lock-area_20090321-180913.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 66 sec Remove/Install battery now ! Device: ZTE-A66 WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/21/2009 6:11:03 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... error: can't run main loader: Finished, time used: 12 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/21/2009 6:12:01 PM] ==== COM113 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 5 sec Remove/Install battery now ! |
03-31-2009, 14:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I am sure that you have wrote your message just after you woke up and you did not thought well before write words like "team has done nothing to help us". Now my question: what was your own action to help us to make solution ? Did you sent to us phone with new hardware for research ? What else you have tried to do ? I suggest you think twice about your words in future. |
04-01-2009, 13:07 | #3 (permalink) | |
Member: 214987 Status: Offline Thanks Meter: 3 | wake up and stop sleeping Quote:
04-03-2009, 00:46 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | We have no other way after this kind of "nice words"... We are going to "deep sleep" for now, and the only reason of this "deep sleep" is you. Thread closed, I see no reason to talk with people who try to talk with us that way without any reason. p.s. if you want to get anything for free in future (f.e. free updates, free support, free respect, anything else for free) you must think before write. |
Sagem Module bugs, no codes ?? | maikash2747 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 07-08-2009 07:32 |
why new pana01 module can't work? | GSM Deals | Infinity-Box | 7 | 07-10-2008 20:23 |
>>> New Qfg Module Bug & Not Connecting To Phone <<< | keaelite | FuriousGold | 2 | 03-08-2008 01:09 |
New Module Fix The Bug | lins97 | FuriousGold | 1 | 05-29-2006 18:22 |
