01-08-2012, 19:14 | #2 (permalink) |
Insane Poster Join Date: Oct 2008
Member: 885074 Status: Offline Thanks Meter: 4 | panama cu COM59 [VCP0] selected module v4.13 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0054]: 0098:00B100000055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6236:8A02:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: G7210SS_C236_M40_00_23 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: MIRROR_HW_PCB01_GPRS_MT6236_S00.G7210SS_C236_M40_0 0_23.BIN_FLNTY9A0A111300KA40 project-id: G7210SS_C236_M40_00_23, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 1 min 36 sec Remove/Install battery now ! |
The Following User Says Thank You to azii0123 For This Useful Post: |
01-09-2012, 17:18 | #4 (permalink) |
Member: 885074 Status: Offline Thanks Meter: 4 | COM59 [VCP0] selected module v4.13 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0054]: 0098:00B100000055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6236:8A02:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: G7210SS_C236_M40_00_23 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: MIRROR_HW_PCB01_GPRS_MT6236_S00.G7210SS_C236_M40_0 0_23.BIN_FLNTY9A0A111300KA40 project-id: G7210SS_C236_M40_00_23, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: D:\aziz\infinity\flash\panama cu 7210\HWK_Suite_Minor_v02.10.006.exe Disconnect... done Finished, time used: 218 min 7 sec Remove/Install battery now ! |
01-09-2012, 17:22 | #5 (permalink) |
Member: 885074 Status: Offline Thanks Meter: 4 | COM59 [VCP0] selected module v4.13 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0054]: 0098:00B100000055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6236:8A02:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: G7210SS_C236_M40_00_23 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: MIRROR_HW_PCB01_GPRS_MT6236_S00.G7210SS_C236_M40_0 0_23.BIN_FLNTY9A0A111300KA40 project-id: G7210SS_C236_M40_00_23, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: D:\\infinity\flash\panama cu 7210\HWK_Suite_Minor_v02.10.006.exe Disconnect... done Finished, time used: 218 min 7 sec Remove/Install battery now ! |
12-19-2012, 09:26 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | what model selected and what cable use for unlock this phone Panama CU? COM4 [VCP0] selected module v4.13 Action: read unlock codes unlock method: read codes Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6236:8A02:8A00]... CPU: MT6236 high speed boot On chip: 0000:0000:0000 status: FF rom: 4D573031 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 25 sec Remove/Install battery now ! |
HWK can flash K750mcu, but can't flash cu | ckkckk | HWK | 20 | 10-12-2005 09:58 |
i need CU-4 for FPS10 | simlockman1 | Wanted Products | 2 | 08-23-2005 01:23 |
FPS-10+SX-4+CU-4+AD-23FS For sale ! | legija | Sell ur Old and Used Stuff | 126 | 07-13-2005 08:20 |
Cu 65 unlock | zoki | Phone Unlocking Codes & Maps | 0 | 07-29-2004 09:03 |
Where I can find .CU Files for Griffin? | Xed | Griffin | 0 | 09-21-2003 21:53 |
