Panasonic G50 Flashing Error Infinity Team, Got this error in Flashing Panasonic G50... Quote:
Any suggestion will be appreciated... TIA |
Make sure bettery is full charge...What is problem in your phone ? B.r. Sunil.:) |
I'm using power supply set at 3.7VDC... Phone just hang and died..tried RESET SETTINGS...same error... |
hello! did you Hold power button while booting and released it only when program asked? Have you used right cable? Handsfree 4pin? Have you used this cable successsfuly before? i have flashed G50 without battery (just with power supply on positive battery terminal) many times- this never kill phone for me. |
Yup... I've been flashing this phone before...same cable, same procedure, same box and same pc... But today I run my luck... |
hello! well, if all equipment tested, procedure well known- must be hardware problem |
Tried using virtual COM ang pure serial com...play with baudrate still the same... See this.. http://rapidshare.com/files/28842205/G50.exe TIA |
It can be that this time you must check phone hardware. I don't think it can be any miracle with software and PC toda, so open phone and check phone hardware. |
Problem with flash chip... Unit has been dropped.. Thanks |
