Old 05-01-2007, 06:29   #1 (permalink)
Member: 42604
Thanks Meter: 187
Panasonic G50 Flashing Error
Infinity Team,
Got this error in Flashing Panasonic G50...
COM4 selected
Device: Panasonic G50,G51
Checking data, wait...
Action: Flash write
"SmartWrite" enabled
Write: Firmware
Write: Map/Customization
Write: Language Pack
Skip: Eeprom
Boot...
Press and HOLD Power button !
Connecting, wait...
Err: boot failed:
Release Power button !
Err: wrong answer, error#01
Boot Fail
Err:
Finished
Remove/Install battery now !
Time used: 7 sec
Any suggestion will be appreciated...
TIA
Old 05-01-2007, 06:40   #2 (permalink)
Member: 432364
Thanks Meter: 270
Make sure bettery is full charge...What is problem in your phone ?
B.r.
Sunil.
Old 05-01-2007, 07:27   #3 (permalink)
Member: 42604
Thanks Meter: 187
I'm using power supply set at 3.7VDC...
Phone just hang and died..tried RESET SETTINGS...same error...
Old 05-01-2007, 07:44   #4 (permalink)
Member: 148515
Thanks Meter: 15,051
hello!
did you Hold power button while booting and released it only when program asked? Have you used right cable? Handsfree 4pin? Have you used this cable successsfuly before? i have flashed G50 without battery (just with power supply on positive battery terminal) many times- this never kill phone for me.
Old 05-01-2007, 07:46   #5 (permalink)
Member: 42604
Thanks Meter: 187
Yup...
I've been flashing this phone before...same cable, same procedure, same box and same pc...
But today I run my luck...
Old 05-01-2007, 07:54   #6 (permalink)
Member: 148515
hello!
well, if all equipment tested, procedure well known- must be hardware problem
Old 05-01-2007, 08:10   #7 (permalink)
Member: 42604
Thanks Meter: 187
Tried using virtual COM ang pure serial com...play with baudrate still the same...
See this..
http://rapidshare.com/files/28842205/G50.exe
TIA
Old 05-01-2007, 19:32   #8 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
Originally Posted by kasamiko View Post
Yup...
Hi,
It can be that this time you must check phone hardware. I don't think it can be any miracle with software and PC toda, so open phone and check phone hardware.
Old 05-03-2007, 05:34   #9 (permalink)
Member: 42604
Thanks Meter: 187
Problem with flash chip...
Unit has been dropped..
Thanks
Panasonic G50 flashing problem zeerik Infinity-Box 1 05-20-2009 17:14
Panasonic G50 Flash Reader ghabera Panasonic 10 06-21-2005 16:18
HELP....Panasonic GD88 Flash Error look4deal Panasonic 1 07-18-2004 18:59
How can i flash my Panasonic G50? DjStriker Panasonic 15 03-02-2004 08:41
Panasonic G50 Language Flash SoftSkiner Panasonic 2 09-11-2003 12:26
Page generated in 0.34642 seconds with 8 queries
