07-04-2005, 14:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | X70 restart problem after unlock |
07-04-2005, 15:38 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I don't think that it's "after-unlock" problem. Pls, download CB2000 (you can find it in "Panasonic" section) and make "Memory erase" function. Also, if no results, it will be good to flash phone with CPK file (customization file). I can't guarantee that this helps for sure, but we have reason to try. B.R. InfinitySupport |
09-08-2005, 08:38 | #5 (permalink) | |
Sometimes it's possible to find some answers in "FAQ" thread: http://forum.gsmhosting.com/vbb/showthread.php?t=207207 How to use CB2000: http://forum.gsmhosting.com/vbb/showthread.php?t=220184 | |
09-11-2005, 14:34 | #6 (permalink) | |
Member: 43802 Status: Offline Thanks Meter: 36 | Quote:
Need help fast. I have done the memory erase.... seen MMI default passed after pressing memory erase on CB2000 Put phone on Vibrate and phone restarts when a call is made to it. I have unlocked the phone again and done the memory erase and the problem is the same.... can you explain more on flashing phone with CPK file ? only see unlock tab in V1.05 A. Where to flash with CPK file .... | |
09-12-2005, 08:43 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Use winmodo and original firmwares. You can find X70 firmware here: http://vts.vlad.ru/~gsm/Panasonic/Firmware/X70/ |
09-12-2005, 22:07 | #8 (permalink) |
Member: 43802 Status: Offline Thanks Meter: 36 | things have taken a turn for the worst... The phone is not turning on consistently now....just blinks when you hold the power button long enough.. it is not connecting to either CB2000 or when trying to flash with Winmodo, it justs says signalling..and nothing hapens after I press the power button.. the battery is fairly low, and it does not seem to be charging, the charging light is blinking but the phone only blinks when trying to turn on with the charger... and after over an how the battery is still low.. the customer is now angry as the phone is now in a worse state... it hardly turns on, and when it does it only blinks... Why is this ?. I need something to tell the customer ?...is this a problem caused by the unlocking or is it a problem with the X70 phones ? |
09-13-2005, 19:37 | #10 (permalink) |
Member: 43802 Status: Offline Thanks Meter: 36 | hard to tell my customer that... they carried it to me powering on fully after first unlock and return to them, the carried back complaining of restarting now it only blinks after another unlock.... seems like I should be looking to pay the customer for the phone... |
09-14-2005, 08:42 | #11 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | after blinking show , chek ur battery voltage if battery voltage show full than try clean jeck and than flashing after flashing it will solve it this problem not in hardware |
P910 restart problem after UNLOCK MSL | .:==di@bila==:. | UST Pro II | 3 | 07-12-2007 17:44 |
6680 -restart problem after unlock! | Supermen! | Nokia Base Band 5 ( BB-5 ) | 2 | 05-15-2007 11:19 |
P910i restart problem after unlock by using create secrity area. | JOEY.CN | Cruiser Suite | 0 | 06-05-2006 15:21 |
X70 strange problems after unlock | chrisonic | Infinity-Box | 2 | 01-03-2006 21:13 |
Panasonic X70 camera problem after unlock? | DanV | Panasonic | 2 | 06-30-2004 13:34 |
