10-04-2016, 14:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | panasonic t50 after privacy reset sail ui lite stop Code: Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038011A6E450C13E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038011A6E450C13E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C66117001CCD11F9BA44D4A75 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : T50 ProdModel : Panasonic_T50 Device : T50 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : EB-90S45T50v1006 SECURITY : IMEI_SW [1] : 35808807050---- IMEI_SW [2] : 35808807050---- BTMAC Addr : 8CC5E112D720 WiFi MAC : 8CC5E112D721 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P4_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 854x480 TOUCH [0] : GT1XX CAM [0] : STOM_HAL_IMGSENSOR CAM [1] : =s5k5e2ya_mipi_raw CAM [2] : ov5670_mipi_raw CAM [3] : gc0409mipi_raw MODEM : konka6580_w435_we_l_hspa_b1b8_co_clock LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038011A6E450C13E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038011A6E450C13E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C66117001CCD11F9BA44D4A75 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Panasonic ProdName : T50 ProdModel : Panasonic_T50 Device : T50 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : EB-90S45T50v1006 [Read Ok] : preloader_konka6580_w435_we_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / konka6580_w435_we_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2033 MiB Scatter saved to : E:\MT6580__Panasonic__Panasonic_T50__T50__5.1__EB-90S45T50v1006\ All done! Done! Elapsed: 00:17:47 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038011A6E450C13E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038011A6E450C13E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C66117001CCD11F9BA44D4A75 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
10-04-2016, 14:14 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Reset Privacy NOT touch any system-related items at all. Seems as it already was damaged or etc. Flashing has reset userdata/settings and it back to life. |
10-04-2016, 14:24 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | PL request appears before launcher starts. Anyway - if you sure about it was done by CM2 - just not use it next time. But better - test on it again, by enabling privacy and making reset. That will be more useful to understand, where can be problem. Last edited by JayDi; 10-04-2016 at 14:32. |
10-04-2016, 15:14 | #5 (permalink) | |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
Code: Chinese Miracle II [MTK module] v 1.57 Operation : Reset Privacy Lock [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038011A6E450C13E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038011A6E450C13E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C66117001CCD11F9BA44D4A75 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! | |
10-04-2016, 15:28 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Thanks for the test. That is was main reason why had asked about make test again - to make sure myself about all is ok and make you sure about it is not CM2 fault. |
11-01-2016, 08:09 | #7 (permalink) | |
Freak Poster Join Date: May 2005 Age: 48
Member: 142994 Status: Offline Thanks Meter: 66 | Quote:
plz share ur firmware | |
