04-28-2008, 15:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | panasonic vs3 flash prob i flash it with infinity box the prob in writing firmware it fails i change with another version same prob so in the end of flash same prob any help COM6 [VCP9] selected Device: Panasonic VS2,VS3 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... boot answer: 03 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:880D Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Panasonic VS2,VS3_eeprom-sta_20080428-155541.2CE.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Panasonic VS2,VS3_eeprom-sec_20080428-155545.2CE.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Panasonic VS2,VS3_eeprom-complete_20080428-155556.2CE.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Verify result: 0000 warning: probably zone write failed Writing: FFS-1/Customization Verifying... Done Writing: Language Pack Verifying... Done Writing: Graphics Pack Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 1298 sec |
04-28-2008, 17:19 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | This means nothing. At least nothing serious that may be related with power-on problem. I suggest you to check phone hardware. Also you can try to write another firmware but check hardware first !! |
EB.VS3 keypad prob | baker69 | Panasonic | 0 | 02-15-2008 19:00 |
How to flash Panasonic VS3? | venki.bg | Panasonic | 3 | 02-04-2007 19:06 |
UPDATE 07 DEC 2005: Panasonic VS2/VS3 flashing | InfinityHelp | Infinity-Box | 32 | 12-09-2005 16:41 |
hello i need PANASONIC VS3 unlock plz | not mobile | Panasonic | 1 | 11-08-2005 15:16 |
I need the Panasonic VS3 Pinouts. | xxg2960 | Panasonic | 3 | 08-22-2005 08:52 |
