04-29-2010, 08:06 | #1 (permalink) |
Junior Member Join Date: May 2006 Location: phillipines
Member: 273001 Status: Offline Thanks Meter: 3 | panasonic vs6 how to flash?? i tried to flash using infinity but flashing failed now phone is dead... here is the log before flashing. Code: firmware database date: 16.02.2010 Loading data, wait... [Infinity Box] v1.78 smart-card: connected S/N: xxxx:xxxx Wait... Device: Panasonic-VS6,VS7,SA7,MX7 Ready Loadng data, wait... Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Read info... imei: 357213001110707 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.24SMARTI_SDB1SGOLDliteV1.1 MMI ver: Mmi:VS6-VN26,Nov15200500:56:32 Done Finished Code: COM13 [VCP0] selected module v1.78 Device: Panasonic-VS6,VS7,SA7,MX7 Checking data, wait... Action: write flash write: Firmware VS6_VS7_SA7_MX7_VQ21_Main.2DM.bin write: FFS-1/Customization SA7_FFS1_ASU_r008_d04.2DF.bin write: Language Pack VS6_VS7_SA7_MX7_LP1142_CnS_CnT_Ml.2DP.bin write: Graphics Pack SA7_GP1105.2DG.bin write: FFS-2/File system SA7_FFS2_ASU_r008_d04.2DS.bin skip: Eeprom Boot ... Press and HOLD Power button now ! s-gold: B0 loading... boot answer: 03 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:880D Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-VS6,VS7,SA7,MX7_eeprom-static_20100429-131344.2DE.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-VS6,VS7,SA7,MX7_eeprom-security_20100429-131351.2DE.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-VS6,VS7,SA7,MX7_eeprom-complete_20100429-131442.2DE.bin backup critical area Done Check memory ... Check memory Done Write ... Writing: Firmware Verifying... Verify result: 0000 warning: probably zone write failed Writing: FFS-1/Customization Verifying... Done Writing: Language Pack Verifying... Verify result: 0000 warning: probably zone write failed Writing: Graphics Pack Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, time used: 111 min 14 sec Remove/Install battery now ! |
04-29-2010, 17:04 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, What is this phone history ? Did you tried to open phone and check it's hardware ? I think you have a reason to check HW due to it may be flash chip problem (partially damaged or bad soldered flash chip or f.e. water inside). |
05-01-2010, 14:06 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, It may be so, but in fact as per our tests it was no this kind of firmware <-> hardware incompatibility. Try to use another flash files. Also, I think that there is a reason to check phone hardware in any case, this kind of phones is quite old (several years old already) and there is a big chance that it may be HW problem. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
