Old 11-09-2007, 13:07   #1 (permalink)
Member: 480351
Thumbs up panasonic x60 solution....
Phone must be in TEST-MODE: * + # + Power
Connecting, wait...
Phone found, wait...
Connection Ok
Unlocking...
imei: 353410007074838
SEC ver: 01.17gX60
SW ver: 00.00:18:22:C21.00
MMI ver: Mmi:GAX60A60.L146.P101,Oct20200412:46:51
Reading [eeprom-sec_353410007074838]...
file saved: backup_eeprom-sec_353410007074838_20071109-212431.07E.bin
Reading [eeprom-sta_353410007074838]...
file saved: backup_eeprom-sta_353410007074838_20071109-212434.07E.bin
No active locks found.
startup mode confirmed
Done
Finished
but still LOCKED... why ?? ( invalid sim )
i have try with flash for many times but nothing happen...
any bug on infinity for panasonic tool ??
thanks
Old 11-09-2007, 13:10   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Make "unlock in any case" box checked.
Also you can try to unlock is as X60 or as X400 model.
p.s.
you must forgot that "funny time" when phone become unlocked after ordinary flashing
Old 11-12-2007, 08:53   #3 (permalink)
Member: 480351
p.s.
unlock any case
fix start up
all box was checked and unchecked
unsuccessfully
btw... whats meaning with ordinary flashing, many files flash from your site, already done, but the result but nothing
but tonight i will try with x400 model unlock, i will post result tomorrow, thx
Old 12-18-2007, 11:26   #4 (permalink)
Member: 95561
Sonork: 1573725
I have the same problem.
I already flash it with another firmware, but its still get lock to its first carrier (vodafone).
Please give another solution.
Old 12-18-2007, 16:59   #5 (permalink)
Member: 148515
hello!
what flash files did you use?
did you try repair eeprom?
Old 12-19-2007, 08:07   #6 (permalink)
Member: 95561
Sonork: 1573725
I already tru these file :
- X6xA40_De_Fr_Es.07M.bin
- X6xA40_Pl_Fr_Es.07M.bin
- X6xA40_Ru_Fr_Es.07M
All process already done. But this phone still locked.
I already try to format eeprom wuth this file :
- x6x_eep_static_01.07F.bin
- x6x_eep_static_02.07F.bin
- x6x_eep_static_03.07F.bin
But it doesnt work too.
Is this infinity bug ???
Old 12-19-2007, 08:17   #7 (permalink)
Member: 130995
Hello,
Try to flash phone with X66A10 filese set.
make unlock as X60 model ("unlock in any case" checked)
if no luck: make unlock as X400 model ("unlock in any case" checked)
if no luck: open phone and see, probably water inside so phone not works well.
Old 12-21-2007, 05:45   #8 (permalink)
Member: 95561
Sonork: 1573725
I Like to try it, but unfortunetlly, that phone has return to *******r.
But i will try when this kind phone come again to me.
Thanks again for your support
Old 06-18-2009, 16:52   #9 (permalink)
Member: 197538
INFINITY TEAM
DID U GET ANY SOLUTION FOR THIS MODEL AFTER UNLOCKING DONE ,.,, PHONE STILL SAYS INVALID SIM
DID ALL SAID FLASHED PHONE AND EEPROM DONE <BUT STILL <<< UNLOCKED PHONE USING X60 and X400 unlock in any case checked ,, ntg still .. ????????
this is phone info :
Connecting, wait...
Connection Ok
Read info...
imei: 353410007969508
SEC ver: 01.17gX60
SW ver: 00.00:18:22:C19.01
MMI ver: Mmi:GAX60A54.L346.P101,Mar7200414:39:09
Done
Finished
Thanks mike
Old 06-19-2009, 05:10   #10 (permalink)
Nokall's Avatar
Member: 13223
Man test this phones using 64K sim , this phone and Newgen donīt work using some 128k Sim , says invalid sim .
this phones are from the time of Dinosaures
The Following User Says Thank You to Nokall For This Useful Post:
Panasonic X60 restarting solution... gabrielgsm Panasonic 25 01-03-2010 07:40
Panasonic X60 solution or not solution gsmnice Panasonic 45 05-28-2004 17:45
X60 panasonic unlock solution Leo140 Panasonic 38 05-05-2004 11:02
How to unlock Panasonic X60 ??? galaxi Panasonic 3 04-08-2004 19:55
How to unlock Panasonic X60? Uvedovle Panasonic 6 04-05-2004 03:01
Page generated in 0.28670 seconds with 11 queries
