06-21-2010, 16:40 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | Device have to be SWITCHED OFF Press Power button now... Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3/1... Err: write1: 00004824 Err: write1: 00004824 Err: write1: 00004824 Err: write1: 00004824 Err: write1: 00005028 Err: write1: 0000582C Err: write1: 00006030 Err: write1: 00006834 Err: write1: 00007038 Err: write1: 0000783C Action-3 Failed[] Operation Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3131040219 FLASH-ID: 89000D88 Parameters Done Check data... STEP-01 in progress... Check data Done |
06-22-2010, 09:53 | #9 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | and when tryiny to unlock it again it give like this Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished is there any possibility to revive it or just i wast time. |
06-23-2010, 11:10 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, If phone can not be flashed with original flasher and can not be connected well with unlock soft - we have no solution to repair this phone. Anyway, double check phone connector, clean it (in most cases these phones is very old and bottom connector may be quite dirty and had very bad contacts) and try again. |
06-23-2010, 12:03 | #11 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | Code: (in most cases these phones is very old and bottom connector may be quite dirty and had very bad contacts) and when i search for x70 unlock in fourum. i found just dead phone. so all this phone had bad connector http://forum.gsmhosting.com/vbb/3274406-post5.html http://forum.gsmhosting.com/vbb/3274415-post6.html http://forum.gsmhosting.com/vbb/f296...ic-x70-758809/ http://forum.gsmhosting.com/vbb/f296...unlock-835533/ |
09-24-2010, 10:56 | #12 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | Same to me as well! Followed the instructions carefully. Battery full charged, pinouts/contact are clean just like new. But X70 killed by Infinity Box during the unlocking process. Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3131040219 FLASH-ID: 89000D88 Parameters Done Check data... STEP-01 in progress... Check data Done Check HW... FLASH supported[89000D88] 1. REMOVE BATTERY NOW ! 2. Install battery 3. Press "Ok" button 4. Power-On phone after instruction Device have to be SWITCHED OFF Press Power button now... Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3/1... Err: write1: 00003018 Err: write1: 00003018 Err: write1: 00003018 Err: write1: 00003018 Err: write1: 0000381C Err: write1: 00004020 Action-3 Failed[] Operation Failed Finished Then try to unlock again. Here's the logfile: Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Now try flashing with Winmodo: WinMoDo SE v1.4 >Signalling... >Signalling recieved... >Parameters exchange Nothing happens. Now, phone is dead. @Infinity Support Please sort this problem asap! Please help us at least revive the phone's power back to normal. :-( |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
