Old 03-31-2008, 11:00   #1 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
dead LG kg 130
I have lg kg130 in dead condition.
when I connect and check its show like 1st boot ok .
but I dont know how to revive it and how to select files.There r 4 files .
firmware
file system
Alchemy data
Eeprom
should I select all these files at same time O r should select 1 file and write then write 2nd and write and then 3rd and then 4th.??????????
Old 03-31-2008, 11:29   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Read info and post here detail log of the phone.
Waiting for u r reply.
Old 03-31-2008, 14:14   #3 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
COM4 [VCP0] selected
Device: LG KG130
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
"keep calibration" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 355311013735768
current otp imei: 355311013735768
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35531101373576 8_LG KG130_20080331-173506.B1E.bin
version: ***-XXV10a07KG130P40
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
flash: 01227E22212200:00000100000000
write: 2nd chip area
error: no any expected answer
error: flash write error: 18194000:00002000
error: error# 000000FF
Write Fail
Finished, time used: 2326 sec
Remove/Install battery now !
Old 03-31-2008, 14:32   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It looks like phone hardware is damaged (damaged or bad soldered flash chip).
Charge battery completely, repeat flash process again. If still no luck reball flash chip.
Old 04-04-2008, 15:26   #5 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
Finally I got success.
I put some packing tape on 3 pasted ic,s.
then flash it with 2 files.
1-firmware
2- Alchemy data.
set is working fine now.
Unlock LG KG 130?? Mapamann HWK 22 04-22-2008 14:46
LG Kg 130 unlock ? reset? alunecosu_hd PolarBox 3 0 12-17-2007 10:21
successfully flash lg kg 130 talatmehmood Multi-Box 1 12-17-2007 10:12
Lg Kg 130 sakka PolarBox 3 3 06-15-2007 22:23
Unlock Off Lg Kg 130 pietpiraat LG 1 05-29-2007 00:27
Page generated in 0.14854 seconds with 9 queries
