12-28-2007, 08:27 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | G500 here i try with selecting G800 but nothing... COM1 [Serial0] selected Device: Pantech G800 Checking data, wait... advanced flash detection active Action: analyze Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22022201:0CE59F00000000 flash: 01227E22022201:0CE59F00000000 flash: Amd PL064J D 8Mb id: 00005260 Boot Done Set baud... 115200 Set baud Done Check flash... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer error: no any expected answer error: no any expected answer file saved: backup_Pantech G800_analyze_20071228-122456.8FX.bin Please, send "backup_Pantech G800_analyze.bin" file to support ! error: no any expected answer Finished, time used: 34 sec Remove/Install battery now ! |
04-08-2008, 09:04 | #6 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 42
Member: 70573 Status: Offline Thanks Meter: 24 | I have same prob with Mr AppleLinks Log here : COM2 ready Testing COM2 at 230400... COM2 [VCP0] selected Device: Pantech G800 Checking data, wait... advanced flash detection active Action: read flash Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22022201:0CE59F00000000 flash: 01227E22022201:0CE59F00000000 flash: Amd PL064J D 8Mb id: 00005260 Boot Done Set baud... 230400 Set baud Done Check flash... Reading[part_1_of_2__Pantech G800]... error: no any expected answer Reading[part_2_of_2__Pantech G800]... error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer: wrong answer after chip id request error: no any expected answer Finished, time used: 90 sec Remove/Install battery now ! Trying with "DATA mode" cable With Pinout from G800 not work Log here : Application: C:\Program Files\InfinityBox\PNModule\PNModule.exe Loading data, wait... [Infinity Box] v1.05 S/N: 0D05:010E Wait... Current device: Pantech G800 Done Action: unlock COM2 [VCP0] selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... error: connection failed, try again ! error: operation not finished properly Finished, time used: 34 sec Power-off phone by "Power" button (don't remove battery). Action: unlock COM2 [VCP0] selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... error: connection failed, try again ! error: operation not finished properly Finished, time used: 34 sec Power-off phone by "Power" button (don't remove battery). Action: unlock COM2 [VCP0] selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... error: connection failed, try again ! error: operation not finished properly Finished, time used: 33 sec Power-off phone by "Power" button (don't remove battery). Action: unlock COM2 [VCP0] selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... error: connection failed, try again ! error: operation not finished properly Finished, time used: 33 sec Power-off phone by "Power" button (don't remove battery). anyone have solution in this Case? Pls help! |
04-12-2008, 03:10 | #8 (permalink) |
Member: 70573 Status: Offline Thanks Meter: 24 | i want unlock Pantech G500 with selected G800 model from infi support but Not work :-)(infi not support G500) Backup error, unlock with DATA Mode not work(HW in two phone very same) sorry for log if lost your time Thanks. |
04-12-2008, 10:21 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @dog_baby Double check "DATA" mode cable ("DATA" mode cable is not the same as cable for flashing !) and try again. You can try to select other model, phone can't be damaged in "DATA" mode. @..::AppleLinks::.. 1. What you talk about ? 2. Do you have phone on hands ? 3. Did you tested it ? Please, post here answers to all these questions so we can understand what you talk about |
04-14-2008, 12:06 | #11 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
1-if u can see above posts,some days ago i post about it...........so it mean soem days ago i check it..this is u 2nd ans 3-ye si chck the phone,this is u r 3rd ans @InfinitySupport plz do not force user to select different phone model,get the phone and add it also.....no need to present ideas more..thats all | |
04-14-2008, 14:59 | #12 (permalink) | |
You have zero knowledge about Infinity-Box unlock procedure, so, please, stop to make Infinity-Box users confusing. So, please, stop to post your genious ideas regarding Infinity-Box in future due to your advices is really non-professional. If you want to show to somebody that you know what you know word CPU this is not a reason to give me stupid advices that I must do and that I must not do. Thank you for your kind understanding ! p.s. read again your own message: http://www./showpo...98&postcount=2 If you even can't press "unlock" button but try to make another action what you talk about here ? Please, try to understand that "unlock" procedure should be done with big "unlock" button but not with "stop" button (or other buttons), hope this will help you in your future understanding of phone structure. | |
11-29-2008, 15:26 | #13 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Hello infinity team i have in my hand pantech q99 they said it is g500 and i want to flash it for french language can i do that with infinity would you like any extra information i am ready |
How to unlock(user lock) Pantech G500, please help me. | Coo | Various | 40 | 01-16-2010 05:59 |
Pantech G500 | ritson | Various | 1 | 09-24-2006 08:40 |
help unlock Pantech G500 | sergkmv | Various | 15 | 03-30-2006 23:39 |
Pantech G500 | ritson | Various | 0 | 03-02-2005 11:53 |
Anybody now new secrets code for pantech g500? | GodMan | Various | 0 | 09-04-2004 12:10 |
