Old 05-19-2008, 11:08   #1 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
>>> pantech PG-6100 flashing bug <<<
hi
just want to ask if whats wrong with it?its stop always in 6%
phone status before flashing is hanging when going to camera only message PLEASE WAIT
tried is all baud speed
also tried in two cables
one cames from Fg
one i have made with this pinout
=== GPRS MODE ===
keyboard top
1.........24
12: Phone Tx (RJ-45 pin-3)
15: Phone Rx (RJ-45 pin-2)
24: Gnd
br
keaelite
Old 05-20-2008, 02:53   #2 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
infinity team any suggestion what to do?
br
keaelite
Old 05-22-2008, 02:20   #3 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
INIFINITY what should you say about this problem?
its been 3days that im waiting for youre kind reply.
br
keaelite
Old 05-22-2008, 03:27   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Did you tried to flash phone again ?
If you will see the error pls check, what is the error address (for different tries).
Did you tried to open phone and check it's hardware (f.e. reball flash chip) ?
Old 05-22-2008, 04:10   #5 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
Originally Posted by InfinitySupport View Post
Hello,
tried flashing this phone within 3days now
error address is the same everythime having error FLASH WRITE ERROR: 01080000:00020000.....flashing stop always in 6%
there is no problem in phone phone is absulutely working before its just hang if you go to camera just saying standby if you will not go to camera phone is working 100%.
tested in two cables and i again made another cable but still same problem
dont be offended but i am sure that this is 100% software problem/bug.
br
keaelite
Old 05-31-2008, 03:10   #6 (permalink)
Member: 578135
Thanks Meter: 13
br
keaelite
Flash the phone with vpower, infinity software have bug in this phone.
Old 05-31-2008, 15:35   #7 (permalink)
Member: 130995
http:///vbb/showpo...3&postcount=21
Old 08-03-2009, 20:29   #8 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
how about Pantech PG3200 problem is when in ringtone menu then hang...
already reset settings/SP unlock all ok but when flash it show error:
Loading file v.02...
PG3200C_HCCC0106172005_v12_Core_En_Ru.8FM.bin loaded
Testing COM10 at 460800...
COM10 [VCP0] selected
Device: Pantech PG-3200
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware
Skip: File system
Skip: Language pack
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Cable must be in "GPRS" mode !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881200010001:89881200000000
flash: Intel 128MBit-T Strata T 16Mb
Boot Done
Set baud...
460800
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Firmware
error: no any expected answer
error: flash write error: 01000000:00020000
Write Fail
Finished, time used: 80 sec
Remove/Install battery now !
pantech pg-6100 flash file ? ::: ANSWERED ::: aleon PolarBox 3 2 09-09-2009 16:31
Help!!!. Pantech Pg-6100 dead paedy Infinity-Box 21 03-30-2009 09:48
Pantech PG 6100 dead after flashing stopped. .:==di@bila==:. Infinity-Box 54 12-30-2008 21:43
Infinity Kill pantech PG-6100 after reset Tan Thanh Infinity-Box 3 03-27-2007 19:45
pantech pg-6100 need flesh with rus lp dimitron Infinity-Box 0 02-07-2007 13:33
Page generated in 0.18917 seconds with 10 queries
