05-13-2015, 16:33 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Pattern Lock Remove Problem Code: Chinese Miracle II [MTK module] v 1.20 Operation : Read PatternLock [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 100 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0081 , [Micron] NAND_MT29C8G96MAZBADKD_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... PatternLock not set Done! Elapsed: 00:01:32 Reconnect Power/Cable! |
05-13-2015, 16:39 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Please, make "Flash Read" , 7zip file and send me. Will be improved in next update and will say correct patternlock, after receive file. |
05-13-2015, 17:24 | #3 (permalink) |
Junior Member Join Date: May 2015
Member: 2393454 Status: Offline Thanks Meter: 0 | s4 gt i9500 mtk have this model of PHone but is it clone Samsung s4 . I hard to search the firmware or cwm recovery of this model but not found is compatible. Please help me. But is phone now boot loop. Board mtk6589 wet lca, hardware 6572, model gti9500 mtk6589 wet Lca, display Alps jb3 mp.v1.8, android version 4.4.4, opengl es version 2.0, screen size 6.13 Inch, screen resolition pixel 480*854, total ram 449MB, is appear on CPU z. Please help me what firmware or stock rom or cus from for this device.. I don't want is phone brick. Phone now boot loop. Attached Thumbnails |
05-13-2015, 17:31 | #4 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | more info needed Quote:
