04-12-2008, 03:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Can we use Pin finder for Voda and Sagem ? Can we use Infinity auto pin finder for these models...How..? |
04-12-2008, 10:13 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Yes, you can use Infinity-Box PinFinder with any phone ! Here is instruction example gow to use it: Manual pinout selection: example Known pinout for Huawei-C2285 model: keyboard top 1.........24 12: Phone Tx (RJ45 pin-3) 13: Phone Rx (RJ45 pin-2) 1.Connect Power cable to phone instead of battery 2.Connect L24A cable (due to total number of connector pins is 24) 3.Select L24A cable in PinFinder Adapter software (according to connected cable) 4.Set Rx (phone Tx) pin value to 12 (according to known pinout) 5.Set Tx (phone Rx) pin value to 13 (according to known pinout) 6.Press “Power” button to enable phone power In case of connection problems it may need to change pin numbering mode (reverse pin numbering) due to different phone connector soldering to PCB. To reverse pin numbering mode from 1.....24 to 24.....1 (and vice versa) press “Reverse” button and then press “Set” button. |
04-12-2008, 21:37 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Quote:
this is excellent work | |
Can i use pin finder with Huawei T201 ? | summer_20xx | Infinity-Box | 9 | 04-01-2008 21:56 |
Can we use this TP for SL75 ? | kasner | SIEM Service Tools | 2 | 03-30-2007 13:21 |
Can We Use FTDI Cables For Sharp 3g Unlocking With Furiousbox | MobilesDoctor | FuriouS II | 3 | 10-05-2005 18:36 |
Can we use Blazer cables for HWK UFS_LG_GSM? | fingusio | HWK | 3 | 09-17-2005 11:54 |
