12-19-2006, 22:19 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Algeria Age: 53
Member: 66566 Status: Offline Thanks Meter: 43 | Pb to install infinity box I have this pb when i install driver for infinity box in my labtop, i need a help urgently please Error 1327. Invalid drive G:\ but i have no drive G installed on my labtop, i think the path of installation is not correct, how to solve that plz ? Thanks before |
12-20-2006, 00:01 | #3 (permalink) |
Member: 66566 Status: Offline Thanks Meter: 43 | Sorry, have another small pb : The windows of main software is not complete (like bad resolution of my screen, but it's not a resolution pb : 1024x768), I can't see all the windows, it's cut ! I can only see Setting and a small part of Flash I hope having a quick answer, or maybe I'll find out by myself before thanks Last edited by Ibn'arabi; 12-20-2006 at 00:33. |
12-20-2006, 01:08 | #4 (permalink) |
Member: 66566 Status: Offline Thanks Meter: 43 | i'm tired now and need help on reading flash of w375i nothing happen, I already had set "Latency Timer" to 4, what to do please ? ================ COM13 selected "smart write" active Action: read flash Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode[00] ================== ps : I also have no full screen of the window of the soft Thx |
12-21-2006, 00:44 | #6 (permalink) |
Member: 66566 Status: Offline Thanks Meter: 43 | ok, thanks, pb is solved for w375, but i can't read flash, because i must lean the cable to make it touching contact inside phone, so i'm concluding that the cable is not vorking well, i will try with t191 serial port cable and send to you full flash if i get success B.R |
01-15-2007, 22:41 | #7 (permalink) |
Registered User Join Date: Sep 2005 Location: Abuja nigeria
Member: 185010 Status: Offline Sonork: alias-albertino Thanks Meter: 170 | after downloading the setup, when i click to install it will give me the the window mesage that says------[[insert a disc with that volume and click ok to try again]------can some one tell me what to do about these problem of my? |
01-16-2007, 00:19 | #8 (permalink) |
Member: 66566 Status: Offline Thanks Meter: 43 | Hello You must change something In Regedit : HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\Curre ntVersion\Explorer\User Shell Folders look at the photo and tell me if you have same, what letters you have instead of % Windows must have a path (a way) when it is installing a software, if the letter of the drive is not correct (it's normally use c:\), windows can't find it by itself, so you correct the good path at regedit as shown show me please what you have in regedit |
how to use infinity box and infinity apf box plus | wahablepirate | Infinity-Box | 10 | 06-14-2012 17:27 |
how to install infinity box | romeo_1 | Infinity-Box | 8 | 10-19-2009 21:28 |
How to install infinity box, need procedure??? | rundll-exe | Infinity-Box | 4 | 05-15-2009 11:04 |
how to install infinity box | zeeshan tayyab | Infinity-Box | 2 | 11-23-2008 13:28 |
New Installer infinity box | khansb | Infinity-Box | 1 | 10-20-2006 19:44 |
