Old 02-13-2020, 23:45   #1 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 249
PCsmart Tab PCSGOB10MVA frp help
Hi, i've been trying to remove FRP from this device, but it is secure DA i havent been able to boot it or do anything at all, can`t bypass it, it has no talkback or anything at all
cpu is MT8163
Operation : Identify [ v2.07 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM22)
MODE : BOOTROM
PORT : 22
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : BASE_v1812 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT8163
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 4400014536303446091E0134BD842CF8
DAInf: 4 : 2 : 161
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 450100444634303634011E09F82C84BD
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERROR : 000007D4 : BROM : DOWNLOAD DA FAIL
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PTFN : PreLoader USB VCOM Port (COM5)
MODE : PRELOADER PORT
PORT : 5
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : PRELOADER PORT
Old 02-14-2020, 01:10   #2 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,382
Ite not secured use only old base
Or juste old infinity mtk module V1.58
Old 02-14-2020, 18:29   #3 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 249
i've tried with mtk v1.58 and it gives me this error
Start  at : [14/02/2020 / 12:23:39 PM]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BB_CPU_NME : [MediaTek] MT8163_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:06
Finish at : [14/02/2020 / 12:23:46 PM]
Start  at : [14/02/2020 / 12:23:51 PM]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x97
NAND Flash : NOT INSTALLED
eMMC Flash : 450100444634303634011E09F82C84BD
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xBC000000
DRAM_INIT_REQ_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:42
Finish at : [14/02/2020 / 12:24:33 PM]
The Following User Says Thank You to bananin For This Useful Post:
Old 02-15-2020, 14:22   #4 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,382
Wink
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:06
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:42
easy bro
download and uncompress it and select scatter file in CM2MTK V1.58 and do what you need like frp rest
PCSMART PCSGOB10MVA ? 7.0_MT8163_20171215
The Following User Says Thank You to rebainoor For This Useful Post:
Page generated in 0.24194 seconds with 7 queries
