Old 04-10-2008, 09:20   #1 (permalink)
Member: 432364
Thanks Meter: 270
Pda phone flash file
Hi
Infinity team,
I have one chinese pda phone....In back lable model number not written....I don't know phone model no....Phone is in dead condition....But connecting to software....I did "read detailed information" n "Complet format"....Here is log
[Infinity Box] v2.30
S/N: *********
Wait...
Device: Autodetect 6205-6227 NOR
Done
COM6 [VCP0] selected
Checking data, wait...
Action: read/check detailed information
Boot...
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:E3E1:8FC5
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Finished, time used: 257 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: reset
Boot...
19200
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
What to do:
.damaged firmware
.damaged hardware
ffs chip: 00
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 178 sec
I m confused n don't know which file i have to flash in phone....Plz help me....
B.r.
Sunil.
Old 04-10-2008, 16:18   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
as i can see in log- you phone flash is completely erased.
now the only way to find suitable flash file for you is by picture.
post here your phone picture, probably someone will recognise it and tell you which flash file to use
Old 04-11-2008, 09:32   #3 (permalink)
Member: 432364
Thanks Meter: 270
hello!
Thx for replay....
http://i161.photobucket.com/albums/t...0042008124.jpg
http://i161.photobucket.com/albums/t...0042008125.jpg
http://i161.photobucket.com/albums/t...0042008126.jpg
http://i161.photobucket.com/albums/t...0042008127.jpg
http://i161.photobucket.com/albums/t...0042008121.jpg
http://i161.photobucket.com/albums/t...0042008122.jpg
http://i161.photobucket.com/albums/t...0042008123.jpg
B.r.
Sunil.
Old 04-17-2008, 02:11   #4 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 187
InfinityHelp PLS NEED PINOUT FOR THIS PHONE AND SOFTWARE
http:///vbb/attach...5&d=1208382912
http:///vbb/attach...6&d=1208382912
http:///vbb/attach...7&d=1208382912
THANKA IN ADVENCE
Old 04-17-2008, 07:56   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@ramoon20
What is phone connector type ?
Need cm pda v13 flash file urgent spnokia2008 Infinity-Box 3 11-08-2009 20:32
chinese pda v13 flash file spnokia2008 SpiderMan 2 05-29-2009 08:33
china dual sim pda N95 flash file needed... -=whitezaNder=- SpiderMan 0 01-18-2009 09:25
Pda Bt Flash File akhil_bbsr Infinity-Box 3 01-18-2008 17:17
RSA phones flash file NOT patch and original.. xileen2k UFS2 + UFS3-Tornadoflasher 0 09-14-2004 14:32
Page generated in 0.27931 seconds with 8 queries
