pendo pndpp44qc7blk MT8127 pendo pndpp44qc7blk tab MT8127 nand pattern key format error :mad: Settings -> Other -> NAND init Mode . all . also but same error :confused::confused::confused: here is log Code: Card found : S/N : 672D292B , v0135 |
Hello, Read file with tick Nand Extra after Read flash,, flash User data only,, for now this the solution |
princesaddam @ thanks for reply Read file to Mich slow read |
read file erorr start read file time , 11:35 end 13:10 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/00 DEV RID : 0x1F7B1D392F5C10721B8D09E21A8144DF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Error] : Bad PRELOADER data Looks like unusable file , break! Done! Elapsed: 01:29:36 Reconnect Power/Cable! |
i still be here waiting and waiting Infinity team |
Sw should make folder with some read data. Send that folder with files in it. |
Read file to Mich slow read 2h after error [Read Error] : Bad PRELOADER data Looks like unusable file , break! (PRELOADER.bin) size 0 byte Quote:
