Old 03-18-2017, 08:30   #1 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 348
pendo pndpp44qc7blk MT8127
pendo pndpp44qc7blk tab MT8127 nand pattern key format error
Settings -> Other -> NAND init Mode . all . also but same error
here is log
Card found : S/N : 672D292B , v0135
Chinese Miracle II  [MTK module] v 1.58
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BB_CPU_NME : [MediaTek] MT8127_S00
BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8D
NAND Flash : 004500DE009400930076005000080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN
[NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008
[NAND] : FLASH_LEN : 0x200000000
[NAND] : FLASH_EXT : 4000/0100/00
DEV RID    : 0x1F7B1D392F5C10721B8D09E21A8144DF
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info! Make "Identify" first!
Operation Failed
Elapsed: 00:00:20
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Info read not done :( Erased/damaged phone?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:13
Old 03-18-2017, 08:35   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 639
Hello,
Read file with tick Nand Extra after Read flash,, flash User data only,, for now this the solution
The Following User Says Thank You to princesaddam For This Useful Post:
Old 03-18-2017, 08:59   #3 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 348
princesaddam @ thanks for reply
Read file to Mich slow read
Old 03-18-2017, 10:10   #4 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 348
read file erorr
start read file time , 11:35 end 13:10
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
[Read Error] : Bad PRELOADER data
Looks like unusable file , break!
Done!
Elapsed: 01:29:36
Old 03-24-2017, 17:42   #5 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 348
i still be here waiting and waiting Infinity team
Old 04-15-2017, 07:06   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
Sw should make folder with some read data. Send that folder with files in it.
The Following User Says Thank You to JayDi For This Useful Post:
Old 04-15-2017, 07:39   #7 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 348
2h after error [Read Error] : Bad PRELOADER data
Looks like unusable file , break! (PRELOADER.bin) size 0 byte
========================= Start =========================
4/15/2017 / 10:32:07 AM
Start at : [4/15/2017 / 10:32:43 AM]
Operation : Read Flash [ v1.58 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Phone found! [ 4 ]
Sync...
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Page generated in 0.24552 seconds with 7 queries
