Old 02-04-2009, 15:16   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
>>> Permanently Blocked Alcatel E227x Unlocked Ok with infinity <<<
Infinity Box unlocked permanently blocked Alcatel E227x (Orange UK) w/o any problems...
However, Code read was also successfully done by Easy Unlocker, but could not enter code as the phone was permentaly blocked..
This phone was unlocked directly by Infinity.. Thanks to this team >>>
COM4 [VCP1] selected
module v1.30
Device: Alcatel-E227
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-E227_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090202-204912.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 65 sec
Remove/Install battery now !
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 02-04-2009, 15:35   #2 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
thanks br good work keep it up...........
Old 02-04-2009, 17:21   #3 (permalink)
Member: 148515
Thanks Meter: 14,898
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 07-01-2009, 21:58   #4 (permalink)
doomstyle's Avatar
Member: 6879
Thanks Meter: 31
COM9 [VCP0] selected
module v1.33
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090701-155548.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 83 sec
work fine i use the cable from the microbox alt e256 work fine
The Following 2 Users Say Thank You to doomstyle For This Useful Post:
Old 08-24-2009, 23:20   #5 (permalink)
Member: 384417
Thanks Meter: 24
unlock alcatel e227x with succes
unlock alcatel e227x with succes by infinity-box
Old 08-25-2009, 01:03   #6 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: (Off Line)
Thanks Meter: 1,810
thanks for info brothers
Old 08-25-2009, 11:55   #7 (permalink)
..::Waqar::..'s Avatar
Member: 904753
Sonork: 100.1583681
Thanks Meter: 2,671
Thanks Brother for info Good Work Keep it UP.
Old 09-07-2009, 14:39   #8 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 66
why infinity didn`t support more alcatels? like e256
>>> Vodafone 725 Unlocked OK with SMTI <<< zeel_zeel SMTi 6 05-07-2009 19:09
now vodafone228fm by zte with counter blocked unlock ok with infinity genci titi 2002 Infinity-Box 2 01-19-2009 13:44
Alcatel-E227 unlock ok by infinity aleem26 Infinity-Box 1 11-05-2008 18:58
alcatel s107 unlock ok with infinity box kopsa2005 Alcatel & TCL Old Models 11 07-02-2008 10:32
>>> T250i unlock ok in infinity <<< keaelite Infinity-Box 2 06-27-2008 10:40
Page generated in 0.28674 seconds with 8 queries
