11-19-2008, 17:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: uk Age: 54
Member: 59789 Status: Offline Thanks Meter: 16 | PFA pro Last edited by InfinitySupport; 11-19-2008 at 18:46. Reason: picture with S/N deleted |
11-19-2008, 18:48 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, What is the problem exactly ? Do you want to use manual or automatic pinout detection ? Did you checked this link: http://forum.gsmhosting.com/vbb/showthread.php?t=526956 |
11-20-2008, 17:54 | #3 (permalink) | |
Member: 59789 Status: Offline Thanks Meter: 16 | Quote:
11-20-2008, 19:27 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, I do not see any problem description. Please, post here answers to the next questions: 1. What is the problem exactly ? 2. Do you want to use manual or automatic pinout detection ? 3. Did you checked this link: http://forum.gsmhosting.com/vbb/showthread.php?t=526956 |
11-20-2008, 21:49 | #5 (permalink) |
Member: 59789 Status: Offline Thanks Meter: 16 | 1 is my connection correct 2 not detecting pinout have a look at my log here software version: 1.15 cable type: 1x12 SE (L12A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM6... adapter found, version: 2000 pins: 12, reversed ! power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 52 sec Power Off ! Set parameter to value 20 (or more) and repeat operation "Finder activation tries" wat i'm doing wrong plz tell me thanks. |
11-20-2008, 22:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, As I can understand you have tried to detect pinout in automatic mode. 1. what is phone model name ? 2. what is phone CPU chip name ? 3. is it your first phone for automatic detection ? 4. did you tried to make "selftest" according to PinFinder manual ? |
11-20-2008, 22:36 | #7 (permalink) | |
yes first fone for automatic detection CPU don't no yes selftest no i just discover pinfinder box is hot why is this. | |
11-20-2008, 22:53 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, If you want to find pinout in automatic mode you must at least select correct CPU chip type. Please, open PinFinder manual right now and read. I am sure you will be surprised how is interesting reading this stupid manual that was written by mega stupid people who thought that users has probably small respect to persons who have spend weeks trying to prepare user manual with pictures. Advice: if you do not want to read manual you must leave this story for now because pinout detection process should be done by high-qualified persons who know what is CPU and what CPU chip type is installed in phone. If you still can not read manual you can set CPU type in PinFinder to "TI" type and repeat pinout detection process, but please, ask your next question only when you will be able to say "I respect people who have tried to prepare that ****ing manual". p.s. Yes, I agree, user manuals was written by stupid persons for for smart persons. But if so, what is the reason for smart people to ask advices from stupid people ? Stupid people who have prepared user manual can give only stupid advices (probably only the same as in stupid user manual) so you do non need to spend your time in discussion with stupid people like me. |
11-21-2008, 14:59 | #9 (permalink) | |
Advice: if you do not want to read manual you must leave this story for now because pinout detection process should be done by high-qualified persons who know what is CPU and what CPU chip type is installed in phone. look i respect you so plz when i'm asking for help you using tis swear ****ing word to me plz. one i always read forum before i ask ? ok dats me if i ask i need help. If you still can not read manual you can set CPU type in PinFinder to "TI" type and repeat pinout detection process, but please, ask your next question only when you will be able to say "I respect people who have tried to prepare that ****ing manual". over the weekend i will sit on tis PFA on get it to work on let u no result ok thanks for ue help ONE ORDA. | |
11-21-2008, 15:07 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, I am sure you did not tried to read manual and you did not tried to read detailed instruction by link that I gave you in previous message. It is very bad that you have ignored my advices and manual. Anyway, here is my answers: if your PinFinder become hot you must follow this way to check PinFinder functionality: 1. open PinFinder manual and read it. 2. connect any phone to PinFinder and make "selftest" according to PinFinder manual 3. try to set pinout manualy, here is an instruction: http://forum.gsmhosting.com/vbb/showthread.php?t=526956 I am sure that PinFinder can not be damaged if you have made everything according to manual, but if you did not followed to manual (I am sure you have ignored it acording to your previous questions) you can damage PinFinder by wrong connection to phone with battery or any other way, this kind of PinFinder can not be replaced by warranty due to it is need to use PinFinder according to manual ! I strongly suggest you to follow my advices at least now ! |
can ust-pro informe me if possible unlock this mobile???? | ayoub_gsm | UST Pro II | 0 | 03-29-2010 10:23 |
Giorgio ****** 134/S Small ********es PFA/JJ | IPMART | ipmart WebShop | 0 | 07-07-2009 11:00 |
Online Unlocking Codes , MT-Pro Logs , SETOOL Box, ULT-PRO , UST-PRO , Infinity PLUS | ..::Mr999::.. | Main Sales Section | 0 | 08-18-2007 05:14 |
flasher dct4 pro pro problem | NNN | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-17-2003 16:17 |
