Pg3210 Telcel Infinity support: I have a Pantech pg3210 from telcel which I already tried to unlock with infinity box with no success. The first operation log I did not make a copy of, but a lock was found and it was eliminated. Eventhough the infinity box says the phone to be unlocked, I put another sim and it asks to change sim. I try again and I get the following operation log: Action: unlock COM3 selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... Phone connected. Working... file saved: backup_sp-unlock_log_20070209-165706.8FX.bin No active locks found, operation terminated. Err: operation not finished properly Finished, time used: 5 sec Power-off phone by "Power" button (don't remove battery). Should I read the flash and send it to you? |
Hi, please, send me the next files from Pantech software folder: operation.log backup_sp-unlock_log_......8FX.bin also, please, read flash backup and send it too: [email protected] Thanks ! |
zukison try the reset code after unlock |
pantech 1410 change sim after flash hello infinity team i have a pantech 1410 that wouñld give me camara busy so i decided to flash it with the telcel flash for 1410 from support area after flash phone powers on ok but says change sim with any sim card and with customers sim card it also says change sim.i have tried to unlock the phone after flash but no success also tried reset code and reset option in pantech software.please help me with this problem BR Gee4234 |
@gee4234 Do you have flash backup from your PG1410 ? If yes, please, send backup file to [email protected] |
no i do not have flash backup i didnt back it up before i flashed the phone big mistake. BR GEE |
Hello, Try to flash phone with PG1400 flash files. I am not sure that it will be good results but let's try. And for make flash backup before this procedure for emergency case to save eeprom calibration values. |
change sim hello infinty thank you for your attention to my problem.ok i have flash the 1410 with a flash file for 1400 from support site now phone powers on and is unlocked but the problem is that this flash does not have 850/1900.seems that telcel flash for 1410 is bad.maybe you can upload a different flash for 1410 to support site. BR GEE |
pantech 1410 hello infinity i just recieved another 1410 for unlock so i went ahead and made a backup of the full flash.i wanted to flash the 1410 that has the change sim problem with the telcel flash from your support site . when i try to load the backup flash infinity doesnt recognize it as a firmware file so i select all files and then i can select it but i get this error: COM6 [VCP1] selected Device: Pantech PG-1410 Checking data, wait... Action: read flash Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Reading[_part_1_of_2__Pantech PG-1410]... file saved: backup__part_1_of_2__Pantech PG-1410_Pantech PG-1410_20080225-121532.8FX.bin Reading[_part_2_of_2__Pantech PG-1410]... file saved: backup__part_2_of_2__Pantech PG-1410_Pantech PG-1410_20080225-121812.8FX.bin flash: 01227E22212200:0CE59F00000000 flash: 01227E22212200:B0800400000000 Finished, time used: 327 sec Remove/Install battery now ! Loading file v.02... Loading failed, probably damaged data file. Loading file v.02... Loading failed, probably damaged data file. please help me with this problem i have to return the phone to the customer working like it was before BR GEE |
Hello, All files that we have already uploaded in support area. Send backup file to [email protected] so we can convert it and upload in support area |
pantech 1410 ctimovil argentina flash backup hello infinty team i have sent the flashbackup to [email protected] please convert and add the flash to your support site as quickly as you can thank you very much BR gee4234 |
Hello, PG1410C_HLMC0111082005_v10 file and eeprom files is uploaded in support area. |
1410 cti argentina backup flash added to support hello infinity Wow!!once again lightning fast support the backup flash i sent was added to support site great work!!i flashed the 1410 with the new flash and it works great thank you very much i can return the phone to the customer he will be happy great support!!! BR Gee4234 |
Pantech pg 3210 Telcel Action: unlock COM58 selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... Err: connection failed, try again ! Err: operation not finished properly Finished, time used: 20 sec Power-off phone by "Power" button (don't remove battery). I can't unlock, this phone i doing right, rj45 cable c300 in usb infinity en fbus, No reset no nothing, the phone is good but not unlock Regards |
Hello, I think it may be a problem with your cable, different cabes types exist. Please, be sure that you have used this cable: === DATA MODE === keyboard top 1.........24 3: connect to phone pin 4 4: connect to phone pin 3 10: Phone Rx (RJ-45 pin-2) 11: Phone Tx (RJ-45 pin-3) 24: Gnd |
