02-16-2009, 13:31 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | PHILIPS 192 can't boot... regards.. COM4 [VCP1] selected module v1.62 Device: Philips-192 Checking data, wait... Action: reset Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... error: can't run main loader: BB try to use another loader type Finished, time used: 14 sec Remove/Install battery now ! |
02-21-2009, 10:09 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | i checked with normal com cable (not box cable) on two pc but same problum COM1 selected module v1.62 Device: Philips-192 Checking data, wait... Action: reset Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... error: can't run main loader: BB try to use another loader type Finished, time used: 8 sec Remove/Install battery now ! COM1 [VCP1] selected module v1.62 Device: Philips-192 Checking data, wait... Action: reset Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... error: can't run main loader: BB try to use another loader type Finished, time used: 14 sec Remove/Install battery now ! please infinyty team solwe the problum |
11-27-2009, 13:07 | #10 (permalink) |
Junior Member Join Date: Apr 2004 Location: RF RK c.Elista 08 Age: 45
Member: 62200 Status: Offline Thanks Meter: 3 | All greetings. I had a problem like that. Programmer Infinity, not via USB and COM port is not able to do. Took to hand the good old Unibox and through COM1 made immediately. The assumption that the USB, COM ports, and + in the Programmers Infinity, something is not completed yet, it turns out that the scheme UNIBOX port is better than in Infinity. And just a normal COM cable can be done and all. I apologize for my English, and that the theme may not be relevant, but all the same. This is my log already repaired the phone. COM1 [Serial0] selected module v1.71 Device: Philips-192 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 007 P192_I7880F_0714B01_V10CN 04.13.00 18.26.13 08.03.00 21 08 2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20091027-145014.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20091027-145015.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20091027-145021.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 27 sec Remove/Install battery now ! |
The Following User Says Thank You to Master911 For This Useful Post: |
03-19-2010, 16:25 | #11 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | but now we have new pcs (new mainboards) and they dont have COM Port.. i have the same error.. COM2 [VCP4] selected Device: Philips-192 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: F8 Finished, Remove/Install battery now ! Time used: 6 sec |
03-20-2010, 08:22 | #12 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
03-20-2010, 16:52 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If you have another cable (f.e. cable based on Prolific PL2303 converter) you can try to use it. Also, try to adjust port settings: |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
07-30-2010, 18:30 | #15 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | I set letency timer to 4 still gives this error: COM4 [VCP0] selected module v1.76 Device: Philips-192 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... error: can't run main loader: FC Finished, time used: 6 sec Remove/Install battery now ! I used standar comport cable without external power: COM1 [Serial0] selected module v1.76 Device: Philips-192 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... error: can't run main loader: F0 Finished, time used: 4 sec Remove/Install battery now ! no any result for half year for this model.. regards. |
Philips-192 user code reset Help ple. | nishue | Infinity-Box | 2 | 02-15-2010 19:22 |
philips 192 simlock error ??? | turkcellgsm | Infinity-Box | 2 | 11-08-2008 14:53 |
Philips 192 tested | nafanya | Infinity-Box | 1 | 06-20-2008 09:28 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 22:02 |
hi I need philips 192 phone code reset | ardagul | Philips | 3 | 03-30-2008 11:57 |
