11-23-2009, 16:16 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | s210 not unlock still with infinity here is log rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20091123-200602.80E.bin Read data done Check data ... Check data done Write ... ......... ......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 63 sec Remove/Install battery now ! |
11-23-2009, 17:21 | #7 (permalink) | |
small question (sorry for it, I am sure you can make everything w/o this my strange suggestion, but anyway): did to tried to make with phone anything else, not only sp-unlock ? | |
11-23-2009, 17:26 | #8 (permalink) | |
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
with main +lp and eeprom too but not affective for this phone to read the sim without its show the insert sim i m sure that it is the software problem ??? | |
11-23-2009, 17:39 | #9 (permalink) | |
I think it's hardware problem. Yes, you can insist that it's software problem, but I am sure it's just your idea but it's not a facts. I suggest you to make "search" in this forum to see many posts about "insert sim". I am sure you will be able to see what was a reason of "insert sim" problem. | |
11-24-2009, 09:25 | #10 (permalink) | |
12-16-2009, 07:53 | #11 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | COM3 [VCP0] selected module v1.37 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! help please!!! |
12-16-2009, 07:55 | #12 (permalink) |
12-16-2009, 16:08 | #14 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | it says press power button not hold!!!! i kept holding button same prob!!! COM3 [VCP0] selected module v1.37 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 51 sec Remove/Install battery now ! |
how to unlock o2x1i with infinity with test point? | ikram tabassum1 | Infinity-Box | 1 | 12-16-2009 08:06 |
samsung s229 spc not unlocking, plz help infinity team | nakshatra | Infinity-Box | 0 | 10-06-2009 06:05 |
ALcatel s210 NOT unlock !! Try all !! | zakiyyboss | Infinity-Box | 2 | 07-22-2009 11:35 |
now vodafone228fm by zte with counter blocked unlock ok with infinity | genci titi 2002 | Infinity-Box | 2 | 01-19-2009 13:44 |
i Can't Unlock G51E with Infinity Box | flechazo | Infinity-Box | 1 | 07-09-2005 14:47 |
