Old 12-10-2009, 10:19   #1 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
philips 192 flash write error
hi infinity team;
I wanto imei repair phlips 192 but it give flash write error
==== log: [09.12.2009 17:42:24] ====
COM1 selected
module v1.71
Device: Philips-192
Checking data, wait...
Action: "repair imei"
new imei: xxxxxxxxxxxxxxxx
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: 8 P192_I7880F_0714B01_V17CNx Jan 8 2008 19 00 28 04.13.00 18.
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20091209-174242.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20091209-174243.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20091209-174249.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20091209-174619.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20091209-174632.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
repair write error [005DA000:0800]...
Ok
Ok
error: write failed[005D0000]
Write Failed
Finished, time used: 299 sec
Remove/Install battery now !
Finished
phone dead ,I flashed like a Device: Digibee-BSNL-G200CF also high speed is possibble
==== log opened: [10.12.2009 11:05:33] ====
Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe
Loading data, wait...
[Infinity Box] v1.72
S/N: 0632:0112
Wait...
Ready
Loading file v.04...
Philips-192_P192_I7880F_0714B01_V17CNx_Jan-8-2008_G1.0_C00.82_En_Tr.B1M.bin loaded
==== log: [10.12.2009 11:05:50] ====
COM4 selected
module v1.72
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL C iew_root_directoryG1.0_C00.82ULC2system-buildmake
Check hardware Done
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 129 sec
phone ok but no imei I try to write eeprom but not success.help me pls.
thank you.
here is all log my work:
Old 12-10-2009, 17:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What do you mean "no imei" ?
Need to know more information about the problem.
Old 12-11-2009, 16:14   #3 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
no imei comes after try to write eeprom like a Digibee-BSNL-G200CF ,but now imei like 004999901......... flashed Philips-192_P192_I7880F_0714B01_V17CNx_Jan-8-2008_G1.0_C00.82_En_Tr.B1M.bin like a Digibee-BSNL-G200CF.
now phone work with corruted imei.
if imei repair philips 192 phone gets dead contion.
if imei repair Digibee-BSNL-G200CF not work
G200CF_lock-area_20091211-171215.B1E.bin
Check memory ...
error: unknown firmware, read flash and send to support
Check memory Failed
Finished, time used: 27 sec
Finished
how can possible imei repair for this phone?
Old 12-11-2009, 18:58   #4 (permalink)
Member: 130995
Hello,
It should be no problems with flashing this model like P-192, there is no any reason to flash/unlock it liks G200 model.
Try to restore original eeprom: Philips-192_eeprom-complete_20091209-174249.B1E.bin
Try to repair imei again like P192 model.
Old 12-15-2009, 13:07   #5 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
hi,I write backup (Philips-192_eeprom-complete ) to phone like Digibee-BSNL-G200CF phone normal with original imei now.but I cannot write any eeprom or flash in p-192 section.only flash or eeprom like a g200 with high speed possibble:
for imei repair:
COM1 selected
module v1.72
Device: Philips-192
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20091214-152905.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20091214-152906.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20091214-152912.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20091214-153238.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20091214-153255.B1E.bin
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Ok
Ok
Ok
Write Failed
Finished, time used: 321 sec
heres my all work again pls check my operation and we solve this problem I think this p-192 different the other
thank you.
Old 03-03-2010, 10:34   #6 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
hi,infinity support
pana01 has philips -192 problem contunie another phone ,same condition.
I cannot repair imei again. I put all progres here
==== [03.03.2010 10:34:41] ====
COM4 [VCP2] selected ''hig speed not possible like philips 192''
module v1.76
Device: Philips-192
new imei: 351049420739619
Boot ...
e-gold: 820000
loading...
next part...
error: can't run main loader: F8
Finished, time used: 5 sec
Finished
COM1 ready
==== [03.03.2010 10:34:59] ==== low speed com1 but gets error phone dead''
COM1 [Serial0] selected
module v1.76
Device: Philips-192
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20100303-103522.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20100303-103523.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20100303-103529.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20100303-103903.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20100303-103916.B1E.bin
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Write Failed
Finished, time used: 5 min 5 sec
Finished
Loading file v.02...
Philips-192_P192_I7880F_0714B01_V10CN_Nov-21-2007_G1.0_C00.74.B1M.bin loaded
COM4 ready
==== [03.03.2010 10:42:39] ==== COM4 [VCP2] selected
module v1.76
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100303-104255.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100303-104256.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100303-104257.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 2 min 6 sec
==== [03.03.2010 10:58:34] ==== ''flashing like a g200 phone alive again also high speed possible''
module v1.76
Action: write flash
error: no data for Firmware
==== [03.03.2010 10:58:51] ====
module v1.76
Action: write flash
Boot ...
error: wrong boot answer #1:
Boot Failed
Finished, time used: 55 sec
==== [03.03.2010 10:59:59] ====
module v1.76
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
sw version: .00 ULC2GL c iew_root_directoryG1.0_C00.74ULC2system-buildmake
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100303-110112.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100303-110112.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100303-110114.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 3 min 1 sec
Philips-192_eeprom-complete_02.B1E.bin loaded ''support area eeprom''
==== [03.03.2010 11:05:50] ====
module v1.76
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100303-110612.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100303-110612.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100303-110614.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, time used: 23 sec
Remove/Install battery now ! '' phone ok but imei corrupt''
==== C:\Program Files\InfinityBox\Pana01\Pana01.exe [03.03.2010 11:15:05] ====
[Infinity Box] v1.76
smart-card: connected
S/N: 0632:0116
Wait...
Device: Philips-192
Ready
COM4 ready
Philips-192_eeprom-complete_20100301-162049.B1E.bin loaded ''old backup eeprom''
==== [03.03.2010 11:16:10] ====
module v1.76
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100303-111628.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100303-111628.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100303-111630.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, time used: 20 sec
Remove/Install battery now ! phone ok with orj imei
pana01 cannot chance philips 192 imei now ,pls check this mistakes
if any suggest I am ready to test
thanks
Old 03-03-2010, 11:54   #7 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
Try to use this software: http://www.infinity-box.com/download...1_v1.77_v1.rar
What is the results ?
Old 03-03-2010, 12:14   #8 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
same
module v1.77
Device: Philips-192
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20100303-130958.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20100303-130959.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20100303-131005.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20100303-131331.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20100303-131343.B1E.bin
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Ok
Write Failed
Finished, time used: 5 min 23 sec
Finished
Old 03-03-2010, 12:32   #9 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
but high speed flashing like philip192 ok
I will report all a few minutes later
Old 03-03-2010, 12:36   #10 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
thank your support it work perfect high speed ''not com1'' imei also chanced
COM4 [VCP1] selected
module v1.77
Device: Philips-192
new imei: 351049xxxxxxxxx
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20100303-133224.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20100303-133225.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20100303-133226.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20100303-133313.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20100303-133317.B1E.bin
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Erasing: eeprom-security
Writing: eeprom-security
Write Done
Finished, time used: 2 min 44 sec
Finished
The Following User Says Thank You to ardagul For This Useful Post:
philips 192 flash write error serkan45 Infinity-Box 4 01-26-2010 13:04
6230i cant flash after mcu flash Write Error ?? AnToS Twisterflasher 16 07-13-2005 20:22
6610 flash write error baraka42 Twisterflasher 4 04-12-2005 12:44
Maxon 7922 Flash Write Error at 101000 ??? While Flashing UNLOCKED Flash File Aamir_Zia Redbox 8 12-09-2004 19:11
3310 flash writing error Moosani Nokia Hardware & Hardware Repair 0 09-02-2003 10:55
Page generated in 0.29193 seconds with 10 queries
