02-25-2009, 11:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Zonguldak, Turkey Age: 55
Member: 56619 Status: Offline Thanks Meter: 62 | philips 192 repair imei fault ==== log: [25.02.2009 12:10:38] ==== COM1 [Serial0] selected module v1.62 Device: Philips-192 Checking data, wait... Action: "repair imei" new imei: 355862010000002 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 P192_I7880F_0714B01_V17CNx Jan 8 2008 19 00 28 04.13.00 18. Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-static_20090225-121134.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-security_20090225-121135.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Philips-192_eeprom-complete_20090225-121141.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Philips-192_imei-area_20090225-121159.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Philips-192_lock-area_20090225-121205.B1E.bin backup critical area Done Check memory ... error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 85 sec Remove/Install battery now ! Finished |
02-25-2009, 13:25 | #2 (permalink) |
Member: 56619 Status: Offline Thanks Meter: 62 | Sorry,i just noticed new version of pana01 in support area.it solved my problem. |
The Following User Says Thank You to krace For This Useful Post: |
philips 192 simlock error ??? | turkcellgsm | Infinity-Box | 2 | 11-08-2008 14:53 |
Philips 192 tested | nafanya | Infinity-Box | 1 | 06-20-2008 09:28 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 22:02 |
hi I need philips 192 phone code reset | ardagul | Philips | 3 | 03-30-2008 11:57 |
best flasher to repair IMEI faults of NOKIA | ktele | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-11-2006 09:42 |
