06-20-2008, 08:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | Philips 192 tested COM1 [Serial0] selected Device: Philips-192 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\phil192\Philips-192_eeprom-sta_20080620-110753.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\phil192\Philips-192_eeprom-sec_20080620-110823.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\phil192\Philips-192_eeprom-complete_20080620-110833.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\phil192\Philips-192_flash_20080620-111516.B1X.bin completed Finished, Remove/Install battery now ! Time used: 469 sec |
The Following User Says Thank You to nafanya For This Useful Post: |
06-20-2008, 09:28 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
PHILIPS 192 can't boot... | KUBAT1 | Infinity-Box | 17 | 08-02-2010 12:57 |
Philips-192 user code reset Help ple. | nishue | Infinity-Box | 2 | 02-15-2010 19:22 |
philips 192 simlock error ??? | turkcellgsm | Infinity-Box | 2 | 11-08-2008 14:53 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 22:02 |
hi I need philips 192 phone code reset | ardagul | Philips | 3 | 03-30-2008 11:57 |
