02-15-2010, 10:15 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Can 't detect ALfatel H!A & H5A???? I tred with pinfinder to detect the set of Alfatel H1A &H5A. Both sets are no-power....but in spiderman it detected with pin 7&9.. So what is the problem in my pinfinder I checked the voltage.... 5v is coming in the out. Also I open the infinith box and replas the diode (short) after that only I recieve 5v but before 4.2v. also Now i have other problem that before I press power button it automatically boot and giving error see the log.. ==== log: [2/14/2010 10:38:24 PM] ==== COM3 [VCP4] selected module v3.05 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! (I did not press power button) error: boot initialization step #2 failed: 5E 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 1 sec Remove/Install battery now ! So what is the problem...Help me sir...also I have the proble on alfatel sets..its not detected on pinfinder.. |
02-15-2010, 13:27 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! some phones reuqire "FInder activation tries" set to maximum value "20" in order to find pinout. try this on your phones. the log which you provided is with spiderman connected? |
02-15-2010, 15:01 | #3 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Also I tried with value 20 but not success... software version: 1.20 cable type: 2x5 (L10C) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 81 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Sir my set is no-power one ...will it detect the dead set??? | |
why pinfinder is not detect alfatel H1,H2.. | sky_finder | Infinity-Box | 16 | 02-01-2010 09:51 |
08 year LG KU990 can 't UNLOCK,ple help me,thx | NO.7 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 12-14-2008 17:41 |
Can 't unlock 6280 | kasner | MT-BOX | 8 | 07-18-2007 00:21 |
can 't download from support | allpk_2003 | MT-BOX | 2 | 01-09-2007 11:57 |
Can@'t activate box | The Repair Shop | FuriouS II | 0 | 06-25-2005 13:15 |
