08-11-2005, 02:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 56387 Status: Offline Thanks Meter: 10 | Flashing C115 Write: Firmware Write: Flex Write: Language Pack Device: C115/C116 Checking data, wait... Connect... Press and Hold Power button... Err: B03: 66746D746F6F6C Connect Fail Finished Remove/Install battery now ! Time used: 4 sec and Write: Firmware Write: Flex Write: Language Pack Device: C115/C116 Checking data, wait... Connect... Press and Hold Power button... Release Power button ! Connect Done Boot... Err: [04] Boot Fail Finished Remove/Install battery now ! Time used: 16 sec I use Full battery, X60 cable, what can i do ??? |
08-11-2005, 14:47 | #7 (permalink) | |
What do you mean "killed" ? Please, describe exactly what's happedn and attach Log file, pls. | |
08-12-2005, 09:42 | #9 (permalink) | |
If you have ordinary T191 COM-port cable (not USB-COM converter) try to use it. Waiting for your results. | |
08-12-2005, 10:52 | #10 (permalink) |
Member: 56387 Status: Offline Thanks Meter: 10 | Here is the log: Write: Firmware Write: Flex Write: Language Pack Device: C115/C116 Checking data, wait... Connect... Press and Hold Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... Set Baud Done Check Flash-1... SW Ver: 3.0.35.E. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: all flash areas Err: write [00000000]: Err: write [00000000]: 00 Err: write [00000000]: D3 Err: write [00000000]: AF Err: write [00000000]: Err: write [00000000]: FF Err: write [00000000]: FF Err: write [00000000]: FF Err: write [00000000]: FF Err: write [00000000]: FF Err: write [00000000]: 35 Err: write [00000000]: FF Err: write [00000000]: 3D Err: write [00000000]: FF Err: write [00000000]: Write Done Failed ! Finished Remove/Install battery now ! Time used: 58 sec This ae the first phone that i flashed with the t190 cable, next all 4 units flash perfect, but now this first unit cant boot. |
08-12-2005, 12:38 | #12 (permalink) |
No Life Poster Join Date: Aug 2003 Location: germany Age: 45
Member: 37112 Status: Offline Thanks Meter: 2 | Device: C115/C116 Checking data, wait... Connect... Press and Hold Power button... Release Power button ! Connect Done Boot... Err: [04] Boot Fail Finished Remove/Install battery now ! Time used: 10 sec same problem with normally com cable not sub |
08-13-2005, 14:58 | #13 (permalink) |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | Device: C115/C116 Checking data, wait... Connect... Press and Hold Power button... Release Power button ! Connect Done Boot... Err: [04] Boot Fail Finished Remove/Install battery now ! Time used: 6 sec Me too, always err: [04], i was set "Latency Timer" value to 4, but still the same!!! Any idea??? Regards |
Error when i try to flash c115 | tasos1971 | Infinity-Box | 1 | 06-03-2006 08:42 |
i try to flash C115 phone is start u | gsm4libya | Infinity-Box | 1 | 05-22-2006 18:12 |
can flashe c115 on smart clip ? | amira77 | Smart-Clip | 3 | 05-04-2006 08:25 |
i need flash C115 Sw 2.0.12.n (colombia) | j_galeano | Motorola ODM | 0 | 12-24-2004 07:21 |
Need Flash C115 language Dutch | Magic2ik | Motorola ODM | 0 | 11-16-2004 16:30 |
