08-03-2005, 01:12 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: 213.16.18 Age: 51
Member: 122158 Status: Offline Sonork: 100.1579859 Thanks Meter: 116 | Philips 568 unlocked locked unlocked locked i have a problem with philips 568 which when i unlock it and after i remove battery the phone become locked. BR |
08-03-2005, 17:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Interesting situation... Please, read flash from this phone (when it become locked back) and send to: InfinityHelp at yahoo.com.hk Also, pls, attach to your mail Log file from Philips software. |
08-03-2005, 20:57 | #5 (permalink) | |
Did you tried to flash phone with firmware from support area and then make unlock again ? | |
08-09-2005, 21:43 | #6 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Earth Age: 42
Member: 5915 Status: Offline Thanks Meter: 7 | i have same problem with all pieces i unlocked what solution for this problem please ?? i have flashed it with firmware from support area but not have frensh lang |
08-09-2005, 23:18 | #7 (permalink) | |
Please, read flash from this phone (when it become locked back) and send to: InfinityHelp at yahoo.com.hk Pls, attach to your mail Log file from Philips software. As about French language: pls, write here language names that you can see in phone after flashing the next flash files: P568_041_LP1-L11.04_De_Fr_Nd P568_041_Main P568_041_Map_AxF.SAx-M9.M08.04 | |
08-11-2005, 10:52 | #9 (permalink) | |
Receiving your mail now. Will check it and inform about results ASAP. | |
08-11-2005, 11:39 | #10 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Romania Age: 48
Member: 124026 Status: Offline Thanks Meter: 27 | Quote:
08-11-2005, 13:09 | #11 (permalink) | |
Please, flash your phone now with any MAP file from support area. Need to flash only MAP file. "Erase FFS" have to be checked. After flashing, don't power-on phone (only remove/install battery) and make unlock. Then pls, test phone. Waiting for your results. | |
08-11-2005, 13:17 | #12 (permalink) |
Member: 124026 Status: Offline Thanks Meter: 27 | thanks for your answer but...i had to give back the phone on my *******r... but until that i flash the phone with P568_041_LP1-L11.04_De_Fr_Nd P568_041_Main P568_041_Map_AxF.SAx-M9.M08.04 (Erase FFS was checked) i remove battery and after i unlock phone, i hope will work... |
08-11-2005, 14:49 | #13 (permalink) | |
Ok, let's see what will happen. And we have some time to analyze readed flash more detailed. | |
08-11-2005, 15:42 | #14 (permalink) | |
Philips 568 Unlock & Imei Change !!! | UFoTeaM | UfoTools | 18 | 09-28-2007 18:51 |
problems to unlock philip 568 | MrNokia | Infinity-Box | 4 | 05-26-2005 17:44 |
philips 568 unlock update in infinity box | mas comm | Philips | 0 | 05-13-2005 07:53 |
unlock philips 568 | osya | Philips | 1 | 05-12-2005 10:35 |
