06-07-2016, 11:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | Philips W6500 phonebook read error Code: Brand : Philips ProdName : W6500 ProdModel : W6500 Device : Philips_W6500_A AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : W6500_M6589A_1342_00_V21A_RU Code: Operation : Read UserData [ v1.49 ] PhoneBook : Enabled PhoneBook : VCFv3 Format output Enabled Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 91 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 5300014534304D453E0528472370BA55 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D30344728053E55BA7023 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xAF9FB39E80EE46E6C66D1DC99A97327A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Error while reading PhoneBook! Code : 0x01 :( Operation Failed |
06-07-2016, 11:43 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. We can try check it. Now, to make sure about it not encrypted - try make "PatternLock" read. It check also FS status and encryption settings. |
06-07-2016, 12:01 | #3 (permalink) | |
Member: 46415 Status: Offline Thanks Meter: 16 | Quote:
tryed with "data protect" and "userdata safe" checked Code: Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! | |
06-07-2016, 12:45 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Bad luck. 4.2.x possible to decrypt via bruteforce key. But not sure about this phone and data inside it will costs enough to cover that try. |
06-07-2016, 12:46 | #5 (permalink) |
